New cassette - chain question
jmsp
by jmsp
I'm thinking about changing my 11-26 cassette to a 12-27 one.
If I change the cassette, should I add another link to the chain?
Thanks
efeballi
by efeballi
It will most probably work fine. Check your current setup in the big-big. If the derailleur cage can still go forward a bit, you'll be fine.
However, the chain will skip over the cassette if one is worn and the other is new.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
eric
by eric
A one tooth difference would be a half link which is not possible on modern bicycle chains.
But as pointed out above the chain you have is likely long enough.
jmsp
by jmsp
Ok, thanks for the advices.
Probably it will be fine without any change in the chain. I'll have to test it.
