Spacers..?
n808
by n808
I have bought two batches of carbon spacers and they are such a crappy product. For one, do they really need to be 3.2mm thick (and "heavy"..)? The 5mm spacer I have on top of the stem end up sticking far outside the top cap. The carbon steerer is only 2.5mm thick (Scott).
Second, they are so inaccurately cut. In one batch, the 10mm one was 12.25mm. Others were cut so crooked I can't use them without sanding them straight, and I am not sure that's worth the trouble, instead of just trying to find some that are well made.
I have bought two different batches, one from an Amazon seller, one from eBay. They were cheap, so it's not a big deal. Does anyone know where some well made ones can be found?
(2012/2014) Scott Addict R1, SRAM Red 6.6kg | 2012 Scott Scale Pro, SRAM X0, 9.4kg
Frankie - B
Administrator
by Frankie - B
Probably in a shop. Big brands want their customers to have good spacers.
Beancouter
by Beancouter
Try BBB ultra spacer , nicely engineered and pretty light too. £9 from chainreactioncycles.
bangkok
by bangkok
high end, but 1/2 the weight of cheapos ....
http://www.carbonice.net/Spacer/Steiler ... r::11.html
mellowJohnny
by mellowJohnny
http://www.chainreactioncycles.com/ca/e ... -prod19638
These are light, and about ½ the thickness of "traditional" spacers I've had. They are only sold as a set, and you can't mix 'n match with other brands either, due to their relative thinness to other spacers.
Out of stock at CRC, but they are around if you look.
kode54
by kode54
you almost have to see them to make sure they are what they say they are. the cheap ones are just trimmed tubes. i'm using the Extralite Delrin spacers. got them from FWB.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
n808
by n808
Thanks for all your suggestions! I have several alternatives to choose from now.
kode54
by kode54
how about these spacers....Point One Racing Nano Second Headset Spacers
from toronto cycles.
http://www.torontocycles.com/Selling/headset.html
10mm spacer = 1.9g
mdeth1313
by mdeth1313
Just received my Point One spacers from FWB and they are rather impressive (and light).
Speedplay is the devil!
lannes
by lannes
these are the best spacers, better than carbon
http://fairwheelbikes.com/cane-creek-ae ... -5711.html
fitty4
by fitty4
Also pop parts spacers are well made and very light
