It is currently Sun Jan 21, 2018 3:50 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Tue May 20, 2014 2:49 am
Hi guys/gals.
This is my first review here so bare with me.
I recently went from my K-Edge Garmin mount to the much lighter KCNC Garmin mount. While this is less of a comparison review there will be some sort of comparison.
First off, ordered this KCNC Garmin Mount from FairWheelbikes:
http://fairwheelbikes.com/kcnc-garmin-mount-p-6066.html
So I had been waiting for the gold one for a bit...they were sold out. My previous mount was a K-edge mount that came in at 50.2 grams on my scale, but they advertise 45 grams. While a great mount, extremely solid, and functioned perfectly I felt that it was on the heavier side for my Garmin 500.
The KCNC came in at 19.1 Grams on my scale but advertised at 19.6 Grams which was surprisingly accurate.
This mount, when first opened, seemed very fragile because they really stripped down all unnecessary metal. The Machined 6061 aluminum seems very clean with no cheap markings or rough areas. It comes in pieces, with no directions and unlike the K-Edge which is very straight forward I had to go the Fair-wheel website to make sure I knew how to put it together correctly.
The KCNC "Clamp Mount" that attaches to the bar has a hinge in it, therefore only requiring one bolt to tighten both "Clamp Mount" and the"Extension Arm" (that controls how far or close the Garmin is to you) with one thin allen screw, unlike the K-Edge that has two big/thick bolts.
The Garmin attaches to the KCNC mount in a much tighter way than the K-Edge. The first time I put the Garmin in the K-edge I was surprised how smooth it was, the KCNC isn't as smooth. In fact, I thought KCNC was broken because it was such a tight fit. Once the Garmin is in the KCNC mount it takes more effort to make sure it is seated properly. Its a MUCH tighter fit. But once its in, its in very securely, more than the K-edge. I have accidentally knocked my Garmin out of the K-Edge before, but I can't see this happening in the KCNC.
As well, once the Garmin is securely in place, you can adjust it up and down with an allen key. This is great for me because when I ride the glare from the Garmin does sometimes blind me when I use the K-Edge.
Overall, the KCNC is a great mount! All of these benefits with less than half the weight of the K-edge! The problems I see with the KCNC is it may not be sturdy for the 800/810. I have tried it with both 500/510 on the K-Edge and its fine. Very solid with no wobbling. I feel that the K-Edge was designed to be able to take the weight of a heavier Garmin, which is does very well. With all of the adjustability, and bling-factor, I am happy with this component. The KCNC Garmin Mount is a TRUE Weight Weenie Component.
PostPosted: Tue May 20, 2014 5:32 am
Just be mindful of the metal contact points "chewing" into the Garmin units with repeated use though.
PostPosted: Tue May 20, 2014 6:54 am
Thats what I was afraid of too. The Plastic is pretty soft on the Garmin unit. Im going to keep my eye on it for sure. Wonder what I can put on the Mount to lessen the Chewing if there is any.
PostPosted: Tue May 20, 2014 8:18 am
19 grams is light, but a true WW mount is roughly 7 grams lighter and made my Tillquist.
But I hear you on the adjustability of the head unit angle to reduce glare; this is a nice option in some situations.
PostPosted: Tue May 20, 2014 1:42 pm
Glare? Just change background brightness of unit. I never have had issues with glare. Even on cloudless days.
There are no new unread posts for this topic. K-Edge Garmin Mount - Regular vs XL
ipenguinking
9
851
Thu Dec 28, 2017 7:22 pm
dim View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. Carbon-Ti hub review
madcow
7
1672
Fri Jan 12, 2018 3:04 am
Hexsense View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
Users browsing this forum: kingsolom0n, normcorriveau, oldnslow2, pdlpsher1, springs, zappafile123 and 31 guests
cron
