It is currently Mon Dec 18, 2017 4:48 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sun May 18, 2014 2:48 am
I'm considering switching from Campy Super Record to EPS with the V2 power unit, but I'm unsure about mounting locations for the new power unit on my Cervelo S2. Anyone have any experience or advice for mounting location or method for the new power unit on an S2 (2011 S2)? I'll likely be upgrading to a new frame that will be more accepting of an internal battery mount.
PostPosted: Sun May 18, 2014 3:15 pm
I have no experience with the S2, but I have two bikes with internal Super Record/Record EPS. Two things to keep in mind, first, the smallest internal diameter of the seat post is usually right behind the bottle cage bosses, make sure you clear those as that is the mounting point. Second, you need to have a way to exit the frame for the charging port. I used the drain hole under the BB for my wife's Parlee Z5SLi and I used the secondary entry hole for the Di2 external battery on my NeilPryde Bura SL.
PostPosted: Mon May 19, 2014 1:51 am
Thanks for the input, but unfortunately the S2 won't allow for internal mounting of the battery. I can run the cabling internally, but I will have to mount the battery somewhere externally. I'm thinking about using double sided tape and zip ties on the chainstay as a temporary solution until I choose a more EPS friendly frame. It won't be elegant, but it will get the job done.
PostPosted: Mon May 19, 2014 3:09 am
In the seat post it's self??
Skunkworks Bikes
PostPosted: Mon May 19, 2014 2:45 pm
Under the saddle. Should fit between the rails. Can't remember the length and since mine is installed inside the frame, it's too much hassle to check.
PostPosted: Tue May 20, 2014 2:13 am
That's an interesting idea. I'll have to check the length of the battery to see if that type of setup would work.
 Post subject:
PostPosted: Tue May 20, 2014 2:22 am
 Post subject: Re:
PostPosted: Tue May 20, 2014 2:48 am
Causidicus wrote:
Why can't you get it in the seat tube? Looks big enough.
According to Cervelo, the battery won't fit in the seat tube. I agree that it looks like it is big enough. I haven't personally measured and I can't find dimensions online, but I'd really prefer if it would fit.
Anyone have insight into the precise dimensions on the S2 seat tube?
 Post subject:
PostPosted: Tue May 20, 2014 2:57 am
PostPosted: Sat May 31, 2014 2:16 pm
Through the head tube is the go and mount in the down tube, just depends on your frame size.
I have done it before on bikes but you will need a special threaded cable install tool or make one.
PostPosted: Tue Aug 05, 2014 10:47 pm
Hello - I am looking to do the same thing with my S2. Did you ever figure this out? If so, what was the solution?
There are no new unread posts for this topic. Attachment(s) How to install a Campy SR 11s fr. derailleur clamp-on 35mm on a Colnago Super?
Kupepe
Fri Mar 17, 2017 12:36 pm
Kupepe View the latest post
There are no new unread posts for this topic. Di2 install help
stub
Thu Apr 13, 2017 12:37 am
stub View the latest post
There are no new unread posts for this topic. Attachment(s) How to install the Canyon Aeroad cf slx 8.00 seatpost
edenn
Mon May 15, 2017 4:40 pm
Shrike View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
22
2611
Wed May 10, 2017 7:13 am
F45 View the latest post
There are no new unread posts for this topic. "improving" Campy EPS switching. Anyone with a non-functional Campy shifter?
2old4this
Tue Sep 26, 2017 1:18 am
2old4this View the latest post
Users browsing this forum: BobbySweeting, bomber, cunn1n9, Google Adsense [Bot], RedbullFiXX, silvalis, wheelbuilder and 42 guests
