It is currently Sat Jan 20, 2018 7:53 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri May 16, 2014 2:07 pm
So bought the other half an upgrade for her bike. Basically changing over from 6700 to 6870 Di2 (I wanted the 6700 kit to sell an old frame off so seemed like a good idea!)
Given it's a slightly older TCR frame the cables are external. Shifters and derailleurs are 6870, the external kit and Junction A are from the earlier 6770 release side of things.
All plugged in and battery attached... Nada (with the exception of a green light on the Junction A when I plug the battery cable into the junction B.
Any suggestions guys and girls?
Cheers!
PostPosted: Fri May 16, 2014 3:18 pm
Have you tried upgrading the firmware?
Not sure that an older junction box will work with the newer kit. Perhaps you should get the 6870 junction box...?
PostPosted: Fri May 16, 2014 3:22 pm
It will work with older junction box. You need to make sure that firmware is same in all components ie. you need to plug it in computer.
PostPosted: Fri May 16, 2014 5:10 pm
Update the firmware of external battery mount
PostPosted: Fri May 16, 2014 10:00 pm
Thanks guys.
PostPosted: Wed Jun 04, 2014 8:43 pm
Just be careful following the instructions: in some systems, drivers may get corrupted if you have the device connected while installing the software
There are no new unread posts for this topic. Di2- 6870 vs 8050...
addicted
Wed Jan 10, 2018 2:42 pm
addicted View the latest post
There are no new unread posts for this topic. Ultegra 6870 di2 dropping chain
raggi
Thu Aug 24, 2017 8:30 pm
kode54 View the latest post
There are no new unread posts for this topic. Ultegra 6870 v 8050 - differences
Timujin
Fri Aug 04, 2017 10:30 am
ooo View the latest post
There are no new unread posts for this topic. Will R8070 levers be compatible with 6870 FD and RD?
Gearhead65
Thu Dec 07, 2017 11:20 pm
achiu View the latest post
There are no new unread posts for this topic. Installing Campy EPS: what do I need?
TonyM
7
588
Sun Nov 05, 2017 6:01 pm
Miller View the latest post
Users browsing this forum: freeriderxy, Google Adsense [Bot], Zakalwe and 49 guests
cron
