2012 Specialized Tarmac SL3 - internal Di2 compatible?
upside
by upside
I am tempted to snag a 2012 SL3..is this frame Di2 compatible or is it just mechanical.. Thanks
Butcher
by Butcher
I have a SL3 [factory Di2] and the wires were run externally. I had to modify the frame to run the wires internally.
There are two fittings so you can mount the battery at the front of the down tube. On the frames that are not Di2, there are no fittings.
upside
by upside
My concern was if there are holes already in place to run internal wires. As far as the battery, I can place that in the seatpost nice and neat. Thank you for your help.
Butcher
by Butcher
With all the research I did [to drill holes and what not], I never found any pictures of a factory SL3 with internal wires of any kind. There were some HTC SL3 frames on eBay that had no cable stops and designed for the Di2 system. I never was able to find close up pictures on how the cables were routed.
