It is currently Mon Apr 24, 2017 12:51 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Mon May 12, 2014 3:22 pm
Did this when installing brake caliper last night.......Am I going to die?
I see white paint under the chip, looks like the black layer was put on after the fork was painted? The yellow discoloration around the hole is the clear coat I put on.
Wish I never went to the garage last night. :|
PostPosted: Mon May 12, 2014 3:38 pm
It'll be fine. Put a thin dab of clear nail polish on it if you feel a need to do something. Not a glob as that could interfere with the brake bolt.
I have drilled out the mounting hole in a carbon fork with no problem (they're two diameters and the large diameter part was about 5mm too long for the brake mounting bolt). CF isn't glass.
There are no new unread posts for this topic. Small chip on my carbon wheel help please??
Allen254
Wed Jul 27, 2016 6:20 pm
Allen254 View the latest post
There are no new unread posts for this topic. Aftermarket aero road disc brake fork
Epic-o
Sat Jan 07, 2017 8:18 am
spookyload View the latest post
There are no new unread posts for this topic. ITM Pyro Carbon Fork
dremeister
Fri Jul 08, 2016 9:39 am
euph View the latest post
There are no new unread posts for this topic. Carbon Rim brake blocks - which is best
oreoboreo
21
1456
Thu May 26, 2016 7:02 am
joepac View the latest post
There are no new unread posts for this topic. Full carbon fork upgrade...
Shaun1977
Wed Nov 02, 2016 1:58 pm
icenutter View the latest post
Users browsing this forum: AJS914, Baidu [Spider], Exabot [Bot], istigatrice, JS300, Majestic-12 [Bot] and 26 guests
