It is currently Fri Feb 24, 2017 12:19 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Thu May 29, 2014 7:12 am
nlouthan wrote:
Post a pic of the frame and/or the BB, then there will be no confusion on our part regarding what you have. Also, what does it say on the BB? Wilier labels everything.
The measurement is in mm, threads inside?
Width of the BB housing measures 93.02mm, outerside to outerside.
Sended from my SingleSideBand Sony Xperia
PostPosted: Thu May 29, 2014 7:23 am
PostPosted: Thu May 29, 2014 9:26 am
Looks like a Willier with BB94.
Campa/Fulcrum crankset will fit since Willier delivers them with these
and they deliver their frameset with something like this:
http://www.twohubs.com/Product/wilier/wilier-bottom-bracket-bearing-kit/712387#.U4buWCgnjCs
PostPosted: Thu May 29, 2014 2:18 pm
On the DS, there should be two holes on the very outside edge of the BB at 3 and 9 o'clock if looking at the BB from the side. That's where the snap ring ends go in. It goes on from the bottom. I use a pick to grab the snap ring and pull it into place. The cranks slide straight in without any spacers. Have you tried this? You might have to wiggle them if you're not pushing straight. Note that no tools are needed for pushing the cranks in. Be sure to try and pull the DS half out after you install the snap ring to make you you have it in the correct place. It slides in further than you might think. On the NDS, you'll need the wavy washer for taking up slack. Then torque down the center bolt and you're done. It is truly a two minute job.
The black plastic spacers from the link above are to run a Shimano or SRAM crank and are not needed with Campy Ultra Torque.
Not sure why there are threads on the inner most part of the BB, but you don't need them.
PostPosted: Thu May 29, 2014 3:26 pm
Hi and thank You very much for answering, there is no visible holes on the BB, I tried to locate them underneath the black paint. The outer part of the BB DS is all solid substance without holes. I mailed the dealer in Holland, hoping I could get some sollution for this matter. Fortunatelly I have Izoard so I'm not totally without bike.
Brgds, Björn
There are no new unread posts for this topic. New 2017 Wilier Cento Air ??
ch00bzs
25
8221
Wed Dec 14, 2016 3:10 pm
htc View the latest post
There are no new unread posts for this topic. Newbie here
roadrunner262
7
484
Sun Jan 29, 2017 6:51 am
evan326 View the latest post
There are no new unread posts for this topic. Rotor Crank Compatability to Wilier Cento 1SR BB386 Evo Frame
theironboy
Sun Jan 01, 2017 2:50 pm
1415chris View the latest post
There are no new unread posts for this topic. Newbie quick release question
walker009
12
442
Thu Apr 28, 2016 7:33 pm
walker009 View the latest post
There are no new unread posts for this topic. Boardman AIR 9.2 2013
Pirlo
Sun May 22, 2016 9:51 pm
Pirlo View the latest post
Users browsing this forum: Bing [Bot], raisinberry777, sp3000, stoney and 25 guests
