Sram Electronic Groupo
ichobi
by ichobi
Theres no reason for SRAM to release a wired e groupset. Di2 is six years old and has it nailed. Unless SRAM can top this, there's not much point getting SRAM when UI2 is already almost as good as DA Di2, and probably cheaper than whatever SRAm is going to sell.
Pretty sure it will be wireless. Though Rotor groupset is interesting. From what J heard from the second largest Rotor distributor in Asia, it will take us by surprise. Electronic probably, wireless may be the technology is here, will e interesting for sure.
pdlpsher1
by pdlpsher1
weenie wrote:with less than 100w but id just imagine a dude in his car)
That 'dude' could be your DS in the team car :D A sudden and unexpected upshift means it's time to attack.
53x12
by 53x12
:lol: :lol: :lol: :thumbup:
alfus1
by alfus1
Sorry but not, full hidraulic group.
euan
by euan
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
alfus1
by alfus1
Belive me, hidraulic. I touch it
53x12
by 53x12
^ You touched the new Rotor groupset? SRAM is pretty clear going to be wireless.
TiG
by TiG
Seems to confirm the wireless at ATOC.
https://twitter.com/joelindsey/status/4 ... 9086021632
pdlpsher1
by pdlpsher1
euan wrote:GCN saying wireless deffo
https://www.youtube.com/watch?v=9Yn_U7v ... M7&index=2
I'm still a bit shocked at the new sequential shift arrangement. Sometimes I push a button on my Di2 to make sure that I'm in the correct front chainring. With the SRAM setup this wouldn't be possible. Plus one cannot shift both the front and rear mechs at the same time. Last but not least both hands are required to shift the FD. So if I have a bottle in one hand I could only shift the RD in one direction and none on the FD.
53x12
by 53x12
SRAM needs to design an EEG cap that goes on under your helmet that can pick up the electrical activity from your neurons/brain saying you want to shift gears. Have that broadcast by ANT+/BT 4.1 to the FD and RD. No need for shifters at that point. More aero and less weight. This is WW after all.
/sarc
ergott
by ergott
Um, as I said before. How is a mechanic supposed to work on the bike? How do you spin the crank if you need both hands to shift the gears?
pdlpsher1
by pdlpsher1
ergott wrote:Um, as I said before. How is a mechanic supposed to work on the bike? How do you spin the crank if you need both hands to shift the gears?
Yes this would be a major challenge. On the positive side once an electronic group is dialed in it doesn't need to be worked on again :D
btompkins0112
by btompkins0112
There is probably a mechanics mode or something similar.....the Bissell mechanics would have pointed that out if not.
Sent from my SM-N900V using Tapatalk
shoopdawoop
by shoopdawoop
I imagine they will add a front adjustment mode or something of the kind; for example you will hold down both levers for 5 seconds and then the drive side shifter will shift the front. Or you will double tap while in adjustment mode and it will shift the front. If they dont add something though I can see that being really annoying!
vdrey
by vdrey
Or maybe a remote?
Sent from my Nexus 7 using Tapatalk
