It is currently Wed Jan 17, 2018 12:26 pm
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Wed May 07, 2014 2:12 pm
So I received my new ti frame and am looking at HS options. It is for a standard external HS. I am looking at CK,CC,Hope,KCNC and maybe Tune.
I am looking for a low stack height as the new frame has a 167mm HT. Weight will also be taken into consideration but not a deal breaker.
So having said that I have had CK for years with zero issues but want to keep my options open.
Looking at either black or red,not sure on that yet.
Leaning toward CC tho.
Thanks Brian
PostPosted: Wed May 07, 2014 2:23 pm
There was a thread recently talking about the unsightly gap at the top of the fork when paired to a CK external HS.
http://forums.roadbikereview.com/components-wrenching/gap-due-ck-baseplate-bevelling-fork-normal-thing-322941.html
You might want to look into that.
And Cane Creek as an option too.
There's sometimes a buggy.
One.
PostPosted: Wed May 07, 2014 2:28 pm
Extralite Head 2 might be a nice WW option.
But I would not overthink this too much. CK is the right choice in terms of pure durability. It truly is a "set and forget" part of the highest quality.
The link to the above story on the gap seems to show a fork that is designed for an integrated headset frame that was mounted on a standard external headset frame. Nothing really wrong with that. I assume your frame has a proper fork for external headsets.
PostPosted: Wed May 07, 2014 3:03 pm
A few years ago I was trying to figure out what the difference was between an "integrated" and "non-integrated" fork.
I believe the only difference is in the shape of the "shoulder" of the fork, with integrated being squared off, and non-integrated being rounded.
Above this there is no difference, ie the fork race area and above would be the same on both types, and either type will fit. The difference is aesthetic only.
That's a long way of saying that I don't believe that the gap in the example in the link is anything to do with the fact that it's an integrated fork. It would be the same with non-integrated. (If you can find one).
One.
PostPosted: Thu May 08, 2014 11:16 am
True, there is a gap due to the design, but a fork designed for external headsets has a shape that flows better (aesthetically) into the headtube. Agreed, no real difference in performance.
PostPosted: Thu May 08, 2014 4:48 pm
Just get a King and be done with it.
PostPosted: Thu May 08, 2014 6:03 pm
If you want a low stack height, would recommend the Extralite. I have two of them and they work fine. CK's are fine, but I think there's also hype with them.
PostPosted: Thu May 08, 2014 10:26 pm
If you don't need the super-low stack then CK is certainly fit and forget.
For lowest height, I have had a lot of success with Extralite. Great quality.
PostPosted: Fri May 09, 2014 12:11 am
I got a deal on a Cane Creek 110 from my LBS. They had one on a demo bike that there were parting out.
The stack on this HS is 16mm.
Thanks Brian
PostPosted: Fri May 09, 2014 12:23 am
Thanks Brian
You really meant "Thanks Julio?" :)
One.
PostPosted: Fri May 09, 2014 10:54 am
Administrator
Chris King is the gold standard. I too used a Cane Creek 110 on my mountain bike and it worked just as well for years until I sold the bike. I imagine its still going strong. Definitely a lower stack height. I would use the 110 on my road bike but my frame was designed to use a King headset and an Alpha Q fork.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri May 09, 2014 10:46 pm
Cane Creek do a lovely external headset as well if you like to spend. I do not bother with CK parts in the main why I have a Token headset in my MTB and it has been there for years through mud, floods and all kinds it still works. It is a headset two bearings on races it is not hard to make a good one without spending a fortune. Still the Cane creek and the CK one are prettier. The most expensive headset I own is an FSA orbit 1" and I spent too much on that too.
www.thecycleclinic.co.uk
PostPosted: Sat May 10, 2014 7:52 am
The Tune headset is really nice, comes with a split crown race and,the compression ring is more kind to carbon steerers than the CK solution. I've had mine on a MTB for about six years, it's very close to a smooth as new, been riding,year around in Swedish climate. I'd say its really a high quality kit. I've had lots and lots of CK units too over the years.
Regarding a headset just being a headset and anyone that doesn't fail will do the job. Well, you could say the same thing about framesets or kitchen knifes, and there would be about as much truth to it... Nice buttery headsets make for nicer feeling bikes.
The Shivenge
There are no new unread posts for this topic. External battery/portable charger options for Garmin
colster
19
1772
Wed Aug 30, 2017 12:49 pm
ross View the latest post
There are no new unread posts for this topic. F10: Which headset top cap options are available?
TonyM
7
621
Sun Dec 31, 2017 11:02 pm
TonyM View the latest post
There are no new unread posts for this topic. Frame Options Under ~$800
mrpillow
25
2472
Mon Jul 03, 2017 10:27 am
shinjiwoon View the latest post
There are no new unread posts for this topic. BBright alternative options....
diegogarcia
Wed Oct 25, 2017 8:24 pm
1415chris View the latest post
There are no new unread posts for this topic. Decent fork options
TheDarkInstall
Tue Mar 28, 2017 4:32 am
froze View the latest post
Users browsing this forum: coriordan, Ettore, Greatestalltime, wingguy and 46 guests
cron
