It is currently Thu Jan 18, 2018 5:20 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Aug 10, 2014 4:41 am
Frankie13, yes I'm planning to use internal battery. In fact, it's the only one I have. A few guys showed in S3 and S5 that it will fit only in the seattube, not in the seatpost. You must place a foam around the battery so that it becomes tucked just above the BB
PostPosted: Sun Aug 10, 2014 4:59 am
Thanks, that's what I thought. Internal batterie is the only way to go, so much cleaner.
PostPosted: Wed Aug 20, 2014 3:55 am
Finished last week my S3 build and was able to mount the internal battery inside the seat tube. I wrapped it with foam and zip-ties. It was a REALLY tight fit in the upper part of the seat tube, but it found it's way around the BB.
I might find it really hard to remove, if needed... that will be a pain.
PostPosted: Wed Aug 20, 2014 6:34 pm
You have some pictures of your finished bike?
Thanks!
PostPosted: Thu Aug 21, 2014 5:25 am
To secure the internal battery I use something called "Ritchey DI2 Seatpost Battery Mount" (available in Amazon.) Though, I was afraid I may not be able to take the battery out later. So, I cut the bottom half off.
PostPosted: Thu Aug 21, 2014 6:24 pm
For round seatposts, I use the 3T adapter which is great! You can remove the battery without effort and the fit is perfect.
There are no new unread posts for this topic. Di2 install help
stub
Thu Apr 13, 2017 12:37 am
stub View the latest post
There are no new unread posts for this topic. Attachment(s) How to install the Canyon Aeroad cf slx 8.00 seatpost
edenn
Mon May 15, 2017 4:40 pm
Shrike View the latest post
There are no new unread posts for this topic. Attachment(s) How to install a Campy SR 11s fr. derailleur clamp-on 35mm on a Colnago Super?
Kupepe
Fri Mar 17, 2017 12:36 pm
Kupepe View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3072
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Attachment(s) Anyway to install bar tape without using electric tape?
Noctiluxx
19
992
Tue Jan 16, 2018 10:17 am
jacobeh View the latest post
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], oldnslow2, silvalis and 38 guests
