It is currently Tue Jan 23, 2018 3:34 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
 Post subject: At home Di2 install....
PostPosted: Mon May 05, 2014 3:56 pm
How hard would at-home setup be for a novice mechanic and first timer?
I just received a new frame-set which turns out to be electronic only, :( . Not only does this increase the cost of my build-out but i'm less comfortable with it. At this point I plan on going Ultegra 6870 with an internal battery. Assuming I buy an upgrade kit off the internet, what are the chances I run into technical problems such as out of date firmware or something more severe? Is the install truly as simple as it appears in videos? Anyone have good luck buying from a certain site that they could recommend?
PostPosted: Mon May 05, 2014 4:23 pm
No need to quote above
I just finished up a Di2 build myself this past friday (Skipped work to play with the bikes :D ). This was first electronic build as normally I am riding a mechanical group. I followed Park Tool's Di2 page as well as Shimano's instructions and it went unbelievably smooth. I am by no means a mechanic but have the basics down and have the tools for the job. I took it to 2 very reputable high performance LBS and they all said everything was done perfectly. Remember if you do this, one of the most important steps for any Di2 install is make sure you in THE METAL SUPPORT PLATE/SUPPORT SCREW for the FD.
A bunch of carbon, with a bunch of electronic parts
PostPosted: Mon May 05, 2014 4:39 pm
Thanks, so all of your parts communicated properly out of the box? Did the battery already have a partial charge or does it need to be charged prior to install?
PostPosted: Mon May 05, 2014 4:44 pm
My battery was half charged out of the box but I threw it on the charger while I built it up so this way it was all set to go. They all communicated perfectly out of the box, I would only go do the firmware update if you wanted the multishift feature and such.
btw heres, what I used to help guide.
http://www.parktool.com/blog/calvins-co ... stallation
PostPosted: Mon May 05, 2014 5:39 pm
I've done a 9070 and 6870 home build with internal batteries on both and no issues. If you're comfortable setting up a cable based system, you should be fine with this...IMHO.
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
PostPosted: Mon May 05, 2014 6:07 pm
Piece of cake. With the internal battery, you load the latest firmware from a windows laptop using the etube software.
PostPosted: Mon May 05, 2014 6:36 pm
It's really quite simple and easy. Go slow, read the directions and if you have questions find the answers before proceeding.
A few things to keep in mind...
-Like 06SpiceRed said- make sure you put the support plate on the frame before installing the front derailleur. Failure to do so will destroy your frame.
-When installing BB be sure that none of your wires get snagged... it's not hard to do but just be mindful as this is one area that they can be pinched.
-You might want to upgrade the battery before installing the whole system as some (mine included) had trouble updating the firmware when everything was plugged in and installed- I had to disconnect everything but the battery and then go ahead.
-Finally, unless your seat post is designed to work with the internal battery you may have to get creative when installing it... My Colnago seat post didn't have the sleeve and collar so I rigged my own attachemtn system...
Good luck!
PostPosted: Mon May 05, 2014 6:59 pm
thanks guys, this is very helpful. As far as upgrading the firmware and battery as some have mentioned, does Shimano ship the software with the group-set or does it have to be purchased separately? Is there any other hardware that would be needed to allow the drive-train to communicate with the PC? I'm planning on using the internal battery mounted to a Thomson post using the 3T battery mount.
Can the internal battery be charged without removing it? Perhaps through a port on the 5-port junction box?
PostPosted: Mon May 05, 2014 7:12 pm
Resident Pro
u will need to remove/unplug internal battery when updating firmware for all other components.
PostPosted: Mon May 05, 2014 8:26 pm
It's charged through the small port on the side of the junction box using SM-BCR2 charger.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon May 05, 2014 9:12 pm
The software is a free download.
PostPosted: Mon May 05, 2014 9:30 pm
When updating the firmware, it's possible to just plug the entire system in and update all at once. I strongly recommend against this. Plug each component in on it's own and update each piece individually as this will eliminate a few bugs that exist only when updating the entire thing. It takes longer to do it this way, but is much more stable in the end.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Mon May 05, 2014 10:15 pm
You can download the e-tube software here:
http://e-tubeproject.shimano.com/
It's very simple to use and will walk you through each step.
When upgrading the system you plug your computer into the junction box and then unplug every component except the one you wish to update. So to upgrade the shifters you plug your computer into the junction box with the usb cables then unplug the derailleurs and battery (at their respective connection points) and then update the software. Plug all the components in and move on to another upgrade in the same manner.
PostPosted: Tue May 06, 2014 12:16 am
I don't think its too hard. Did it on the Di2 Gen I and a couple weeks ago on the 9000. Still harder knowing your frame and what the holes and grommets are for, and does the cable housing thread through the TT or not.
A few things -
-The connections like a snap. No snap, mean loose connection. Found that out an hour before the maiden race.
-The seat post battery is cool, but for many bikes if things are not plugged into the battery and junction box (internal) well, you would have to remove the BB to fix it.
-If upgrading firmware - the software like one thing plugged in at a time. So while you may start with all parts plugged in, you will end up unplugging most items.
PostPosted: Tue May 06, 2014 4:33 am
One advice I would give is to make sure to leave some cable slack at the shifter cable connections. This step is found in the Shimano installation instructions. The professional mechanic who installed my system omitted this very important step. I learned about this problem when I hit a pothole and lost both FD and RD shifting. Came to find out BOTH connectors got disconnected when I hit the pothole. The force of the impact caused the shifters to bend downward hence disconnecting the connectors when there was no slack in the cables.
There are no new unread posts for this topic. Di2 install help
stub
Thu Apr 13, 2017 12:37 am
stub View the latest post
There are no new unread posts for this topic. Attachment(s) How to install the Canyon Aeroad cf slx 8.00 seatpost
edenn
Mon May 15, 2017 4:40 pm
Shrike View the latest post
There are no new unread posts for this topic. Attachment(s) How to install a Campy SR 11s fr. derailleur clamp-on 35mm on a Colnago Super?
Kupepe
Fri Mar 17, 2017 12:36 pm
Kupepe View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3107
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Attachment(s) Anyway to install bar tape without using electric tape?
Noctiluxx
19
1076
Tue Jan 16, 2018 10:17 am
jacobeh View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], Gavin929, hannawald, praem, tonytourist, Zitter and 43 guests
