half-shifts after hitting bumps?
Mize
by Mize
Oh I'm going to check it for sure. Pulling apart the cage is no problem.
Sent from my LG-D800 using Tapatalk
Mize
by Mize
Zero wear on the RD cage.
Mize
by Mize
So these are ruled out:
1. soft pulley wear
2. cable fray/wear
Left to check
1. RD hanger (though it was good 3 weeks ago with no drops since)
2. Internal cable routing - I suppose LBS that did the original build might have crossed them. This one is NOT easy to check.
Twinning
by Twinning
Mize wrote:So these are ruled out:
1. soft pulley wear
2. cable fray/wear
Left to check
My rd hanger kept bending repeatedly without being dropped. Don't know the cause still but the problem is gone
Mize
by Mize
Checked the hanger this morning and it's good.
dunbar42
by dunbar42
To check for crossed cables look to see which side the cable enters the down tube. Then flip the bike up so you can see the bottom cable guide and see which cable moves when you shift. It's really easier than that if you know what to look for but this method will allow you to quickly check and be sure. Crossing cables isn't necessarily a bad thing but it sounds like it may be your issue since it only corrects itself by shifting the front.
Mize
by Mize
Yeah, on the AR1 the cables are in teflon-looking guide tubes but I will do something similar. You certainly cannot feel resistance on the RD cable when you slide it back and forth with your fingers...
dunbar42
by dunbar42
The easier way to tell is the right shifter cable should enter the right side of the down tube. The left shifter cable should enter the left side of the down tube. If they don't then the cables are crossing in the down tube. All directions would be as you're sitting on the bike in the riding position looking forward.
Mize
by Mize
dunbar42 wrote:The easier way to tell is the right shifter cable should enter the right side of the down tube. The left shifter cable should enter the left side of the down tube. If they don't then the cables are crossing in the down tube. All directions would be as you're sitting on the bike in the riding position looking forward.
Huh? The left shifter is the FD and the FD mech is furthest to driver's-side-right. This is why the FD enters the driver's right side of the downtube.
Mize
by Mize
Anyway, the cables ARE reversed. My LBS that did the build has them crossing right before the BB cable guide.
Lovely, eh?
Will managed to reroute them tomorrow.
bombertodd
by bombertodd
The bright side is that you isolated the problem. Enjoy the ride!
Mize
by Mize
Well it's actually worse than I thought.
I pulled it all out and this frameset (AR1) is supposed to have three "mousetail ferrules" - basically a ferrule with a long stretch of teflon tubing to house the cable around turns at the BB/chainstay. Well instead of three, the LBS managed to build my bike with only 2. There is no mousetail in my chainstay. The bummer there is that there is a bend in the chainstay at the dropout so the cable has been rubbing directly on the carbon every time I shifted for 1600-1700 miles. Yay LBS!
Now I have to get a new cable set and frickin' basically rebuild the bike which is my racer. At least I don't have a series race this weekend. Time to tune up my B-bike for team rides.
mattr
by mattr
Seems to be quite apt.
viewtopic.php?f=14&t=121761
Yes it is more cost effective when your LBS can't even follow simple instructions.........
