BB30a and Shimano Crank
Please allow me to step into this thread. For full disclosure: I am the founder and owner of Kogel Bearings.
We developed a bottom bracket specifically to fit a Shimano or GXP crank on the BB30A without any use of adapters.
it is available through our webstore. This forum does not allow me to post a web address due to our newly made account. You will find us quickly with a google search or at kogel dot cc.
If you have any questions, I will be available through email at info atkogel dot cc
Best regards,
Ard Kessels
Best regards,
Ard Kessels
have been using c-bear Synapse bottom bracket for gosh almost a year now. Been using their osbb-campagnolo since 2012, solid as a rock. They are the first one to come out with a no creak bottom bracket solution for campa users. Look like they have a bottom bracket for all sorts. Very happy. Send them an email, quick reply and patient with questions. Pleasure to buy from them.
It looks like the "instanity" is a bit reduced as now the Evo joins the Synapse with BB30A.
- Tinea Pedis
- Contact:
What's the situation with adapters to run 24mm cranks?
- Tinea Pedis
- Contact:
Anyone...? Specifically Rotor 3D24.
- prendrefeu
- Contact:
TP:
http://wheelsmfg.com/bottom-brackets/ca ... ?limit=all
Might be the ticket? Is the spindle a standard 24 or is it "special" like the GXP and has a quirk to it?
There's BB30A on the CAAD12 as well, but I'm going try running the SRAM Red BB30 crankset with it's standard short spindle (the BB30 Force has a longer spindle and goes into BB30A automagically) ( ). I just removed the preload adjuster to get that additional 5mm I needed.
I second Kogel and there is c-bear too:
https://www.c-bear.com/en/products/bott ... face-rotor
Is rotor 3d24 compatible with standard shimano BBs? If it is then there is BBInfinite too:
http://bbinfinite.myshopify.com/product ... it-shimano
- Tinea Pedis
- Contact:
It is (compatible with standard Shimano BBs).
nemeseri wrote:I second Kogel and there is c-bear too:
both are fine for CAAD12, (42 mm) but not for S6 Evo HM 2016 (PF - 46)
the latter gets my vote because the left and right sides are connected
GT56 wrote:nemeseri wrote:I second Kogel and there is c-bear too:
This is crazy! I just checked and kogel and c-bear indeed has different BB30a bottom brackets for the CAAD12/Synapse and S6 HM. I wanted to go with bbinfinite for my future HM S6. It seems they don't have that BB.
prendrefeu wrote:TP:
Hi, How's your experiment on SRAM RED BB30 crank on CAAD12 BB30A? I'm goona do it if there's good news on your project.
- iliedanila
http://kogelbearings.mysimplestore.com/ ... ano-cranks
This is what you need.
Sent from my SM-G928F using Tapatalk
