ultegra 6770 vs DA 7970
fancycoconut
by fancycoconut
I am upgrading to di2 10speed from ultegra, staying with 10 speed because 10speed junior cassettes are much more common in wheel vans than 11 speed junior cassettes.
I was originally planning on buying DA 7970 from a friend, but now i am considering buying 6770 because of the e-tube system, and reformed tech. I will only be buying FD,RD,shifters, battery etc., no brakes (i have cnc brakes), or crank (pmeter). what do you guys think? I think 6770 is heavier than 7970, besides that i dont know...
e
sharkman
by sharkman
Go 6770, although DA7970 is a bit better/lighter (in fact I believe it's even more reliable than the new 9070) in time you will only need a 6870 rear mech chain and 11v cogset to "upgrade".
The four wire protocol of the 7970 will die a slow death and parts/cables will become more expense/harder to obtain in the near future.
glepore
by glepore
Go 6770, although DA7970 is a bit better/lighter (in fact I believe it's even more reliable than the new 9070) in time you will only need a 6870 rear mech chain and 11v cogset to "upgrade"The four wire protocol of the 7970 will die a slow death and parts/cables will become more expense/harder to obtain in the near future..
:thumbup: Wisdom. Get the internal battery and etube software as well.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
