130 BCD chainrings
by JohnnySea
Quick question - what are the smallest rings I can fit to a 130 BCD crankset?
I have both Shimano DA 9000 and Campagnolo SR and want to get as close as I can to a compact without having to buy a new crankset.
by otoman
Age and treachery shall overcome youth and skill
Courir c’est mourir un peu
5 8 5
by 5 8 5
Campag is 135 BCD and 39t
by FIJIGabe
Shimano DA9000 uses a 110BCD for all rings, so you could go with a 50/34T combination all the way up to a 55/42T.
by JohnnySea
Thanks all and particularly FIJIGabe. That's helped make my mind up.
Think I'll dump my SR and 7900 groupsets and upgrade to 9000.
by Stolichnaya
Or just get a Campy crank with 52 - 36 and not compromise...
by rma
I think that if you can spend the premium, go for the DA9000 (or U6800 or even 105 5800). Like FIJIGabe said they use one BCD for all chainrings, but you must use the compatible chainrings. I don't know if the crankarms and the chainrings from the three groups are cross-compatible.
by efeballi
rma, 52/34 and the like were being used in TdF by Shimano sponsored teams. It does degrade shifting though.
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
by veloflyte
Shimano will accept a 38 tooth. Campagnolo will accept a 39 tooth.
by mattyNor
The 9000, 6800 and 5800 stuff is all interchangeable
Sent from my SGH-I337M using Tapatalk
