anyone use jagwire elite link?
- Contact:
i've got them on both of my road bikes... love them.
I used Jagwire Elite Link under the tape with my old build before I crashed it...no issues.
The only issue I’ve come across with the link housing is after a few months, the links start creaking as they bend against each other. This drove me nuts for a few days because I thought my headset was creaking. Eventually I realized where the creaks were coming from and massaging a drop of chain lube over the links got rid of it.
Hi! I'm using Jagwire Elite Link. The problem is that cable rubs against adjusting screw. As I understand design adjusting screw works as ferrule and requires housing ends exactly before hole.
Jagwire ferrules has 6mm diameter and not fits. I used 6mm-5mm adapter included. But 5mm part of adapter just 10mm long and does not reach the end of adjusting screw. Also Jagwire liner has 2.7mm diameter and can't pass through hole in adjusting screw.
Is there a common solution? I see two options. First: remove adapter and ferrule, use links as "housing". Second: drill adjusting screw to pass through liner. I really don't like second
Thanks for advance!
Thanks for advance!
https://road.cc/content/review/229083-y ... ble-system
https://www.bikeradar.com/road/gear/cat ... ion-47814/
I have heard these cable system are extraordinary...
我從使用 Tapatalk 的 Pixel 發送
On three bikes so far and you can mix-n-match with colors for a custom look.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
2015 Rca/NOS(sold).
Yokozuna is good, but it's heavy. I've run them for several years, and never had any issues with them.PrinceEdward wrote: ↑Thu Aug 02, 2018 3:42 pmhttps://road.cc/content/review/229083-y ... ble-system
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
