What Mini Pumps are There with Flex Hose Connectors?
Valbrona
by Valbrona
I know there are the Lezyne ones, but even the shortest is a bit too long for my liking. But are there any other mini pumps that connect using a flexible hose as opposed to traditional push-on Presta fitting ... that are very short? Thanks.
project3
by project3
air canister? you prefer low air volume mini pump over the function?
jekyll man
by jekyll man
http://www.birzman.com/products.php?src=prod&prod_sn=168
I've got one; not used it yet (is that a good thing??) . Doesn't seem to mate very well with various valve extenders i had lying around though....
Official cafe stop tester
OliverRB
by OliverRB
Bontrager Air Support HP Pro S might work for you
BRM
by BRM
Topeak RaceRocket HPC
http://www.topeak.com/products/Pumps/racerocket_hpc_cb
18,3 Original lenght
72 gr Original weight
17,6 cm lenght (without dustcap/rubber endcap)
70 gr real weight (without rubber ends)
useful pump with integrated schrader and presta adapter combo
zwingz
by zwingz
I have the RaceRocket HP, non carbon and find it small enough to fit in a jersey no problem. The flexible hose is definitely a great feature. Obviously it is weight weenies, so the carbon one saves 13g.
