Hex tool diff
project3
by project3
I was ask to invest a better hex tool like parktool or Pedro's. Hardware shops has the same thing and so much cheaper. I will avoid those from magazines giving out free on certain issue but is there a needs of buying bike specific tools? Brand like for cars or home use like stanley or snap looks the same to me.
Ozrider
by Ozrider
As long as it is good quality from a reputable brand it will do the job.
Cheap tools are a waste of money and often break / twist / bend and in the process cause damage to whatever you are working on, and can cause injury in the process.
Ozrider - Western Australia
hunyak
by hunyak
Bondus ball drivers are the best hex keys available.
AndreLM
by AndreLM
I bought a KCNC set from fwb, and they are actually really nice.
goodboyr
by goodboyr
You want the best?
Get the PB Swiss color coded 100 deg keys.
dogg
by dogg
yeah, those pb swiss wrenches are supposed to be the best
but I've had a no-name set of $20 taiwanese allen keys for close 10 years now and they've worked just as they should
BRM
by BRM
A higher class tool has a better fit. Not only when its new but also on the long term it keeps its tight tolerances.
The tool keeps its shape but also the heads of your bolts undergo less damage.
+ when you really have difficulties to get a stuck bolt loose, then a good tool with tight fit can make the difference.
Successful unscrewing vs destroying the head.
Most times no need to buy from a bike-tool-brand neither all tools from one brand only.
Always just look per tool what to buy.
goodboyr
by goodboyr
This^ . There is a reason good tools cost more. Tolerances, material properties.
jpanspac
by jpanspac
A lot of cheap Chinese-made tools will rust quickly in a humid location. Ask me how I know.
My favorite components are the ones I never have to think about.
mattr
by mattr
Cheap tools are easy to refinish (grind the tip off to get a fresh one) unfortunately, they need this treatment regularly.
My expensive tools only need refinishing if I'm a ham fisted Muppet.
They also take ages to do, and eat grinding discs.
Make of that what you will!
BRM
by BRM
jpanspac wrote:A lot of cheap Chinese-made tools will rust quickly in a humid location. Ask me how I know.
Use Boeshield T9 to protect your tools. :wink:
BRM
by BRM
mattr wrote:Cheap tools are easy to refinish (grind the tip off to get a fresh one) unfortunately, they need this treatment regularly.
regrinding a hex tool does not make the Original tolerances tighter. You still will have a mediocre fit.
regrinding a torx? nah . . .
a socket wrench?
a Philips screwdriver?
etc
Geoff
by Geoff
Whoa. Snap-On tools are not 'cheap' tools. I believe that they are still made in the USA, too. Some of the tools that I have were made in the '50s and are still in perfect condition.
The only reason that you may need cycling-specific tools is for special applications (chain tools, bottom bracket tools, etc.) or where clearances are not achievable with 'conventional' tools, which does occur a lot with bikes.
desperado95219
by desperado95219
I use Park tools at home, but just carry hex wrenches I need from the local hardware store (Ace) with me on the bike...they are only a buck or two each and work fine for years. You just don't use very often. (and I don't have a steel bolt on any of my bikes).
steel515
by steel515
hunyak wrote:Bondus ball drivers are the best hex keys available.
Is "hex plus" tool the same, or different?
