Fitting mechanical to a Di2 frame
CIANSUTCLIFFE
by CIANSUTCLIFFE
Hey guys,
Does anyone know if you can run standard mechanical (shimano) through a di2 specific frame. i know it says Di2 specific but can it be done? i have heard of a conversion kit but cant find it anywhere on the internet. can you help me?
specifically referencing theFELT 2011 F1 FRAME
Maybe superDave could help me on this.
thanks
emorydptt
by emorydptt
The problem is you will not have appropriate entry points for the cable housing to route.
It's easier to make a mechanical frame di2 compatible by either drilling or using external cable kit with the cable specific tape rather than making a di2 frame mechanical.
Good luck.
my YouTube channel- keep the grams down and the watts up!
-2014 Cipollini Bond EPS | 2017 enigma echo SR11 | 2011 Time RXR ULTeam SR11 | 2010 Colnago EPS SR11 | 2013 Colnago C59 SR-EPS | 2011 Colnago Prestige Di2 | 2013 Specialized Shiv TT SWorks SR11
Stefano
by Stefano
Might be possible if the same frame/ layup has a mechanical sibling. Get us some close ups of the cable stop area where the electronics enter, and also a production photo of the same area on a mechanical one, that way the peanut gallery actually has something to argue about
ryan0380
by ryan0380
I was considering purchasing a storck fenomalist di2 specific and putting mechanical group on but I decided against it but I will be keeping my eye on this thread
wpccrunner
by wpccrunner
simple, easy, ugly solution is full length housing, but I don't recommend it.
Butcher
by Butcher
I just removed the cable guides from my Tarmac so I could run my EPS. Let me know if you want them. They were riveted and seemed that would be easy to do.
SuperDave
by SuperDave
CIANSUTCLIFFE wrote:Hey guys,
thanks
Yes, you can bolt on mechanical cable guides to the 2011 F1 frame. We equipped the F1 with SRAM RED for some distributors. Your frame came with the guides and your Felt dealer can source additional items. They are also used on our CX bikes.
Found here:
http://2013.feltracing.com/Norway/2013/ ... ides-.aspx
-SD
