It is currently Sun Jan 22, 2017 1:40 pm
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Wed Apr 16, 2014 10:29 am
Banned
https://www.flickr.com/photos/69097995@N04/
The front mech. I had to replace the bolts that hold the self made carbon plate for countersunk ones as they hit the crank arm.
They are now gold. I also have now cut out all the back cage. Its up and running on my bike and working fine.
I have tuned another front red mech and it is lighter. I will post as soon as I get a chance.
The rear mech. I just cut out as much as I thought I could get away with. Its under 90grms nearer 80 but my kitchen scales are useless.
I have a AFC and one carbon Jockey wheel they weigh 5grms the pair.
Sorry for the lousy shots but will try and sort out some better ones.
cheers Xena
PostPosted: Wed Apr 16, 2014 10:34 am
Administrator
You need to use a photo host and can't host the pictures from your AOL account, they won't appear.
RESIDENT GRUMPY OLD MAN.
PostPosted: Wed Apr 16, 2014 11:14 am
Banned
Thanks. I think it should work now.
PostPosted: Wed Apr 16, 2014 11:23 am
:doh: Great pics.
PostPosted: Wed Apr 16, 2014 11:48 am
My 18 month-old niece takes better pictures with her carton of apple juice.
PostPosted: Wed Apr 16, 2014 12:20 pm
Banned
I did say they are lousy. I just thought something was better than nothing. They are just edited from a flip.
I will post some better ones using a camera if I get a chance and obviously take a course in photography :lol:
PostPosted: Thu Apr 17, 2014 1:56 am
I dig it. Thanks for posting.
Trek Madone 7.9 58cm 14.9lbs
PostPosted: Thu Apr 17, 2014 3:07 am
It's kind of like looking at paintings of the parts. How did the derailer become red colored? Have you tested them out on a bike?
PostPosted: Thu Apr 17, 2014 9:44 am
Seems a shame to have spent so long doing the tuning but then not to show off your work more clearly :mrgreen:
PostPosted: Thu Apr 17, 2014 11:28 am
Banned
I apologise again for the photos.
I just did not have the time to get some cool ones up and thought that some of you WW would be interested to see a couple of my tunings.
Even with the bad photos.
I will post some better ones as soon as I get a chance.
The rear mech was a brand new Sram Red Black that I went at with the dremel. When it was finished I gave it a thin coat of red paint.
It has plastic and very light alloy bolts a carbon cage from fibre lyte at the rear. AFC and a carbon jockey wheel ,5grms pair.
I have not put it on a bike yet. Will do soon.
The front mech a Sram red black is on my bike and has been working well since I put it on over a month ago.
I did take out a lot more weight by cutting out more of the titanium cage at the rear. Most of it in-fact.
I have also tuned another red mech which is even lighter.
:beerchug:
PostPosted: Thu Apr 17, 2014 3:06 pm
I had the understanding that the Red front shifter was not very good due to the titanium cage. With all those additional holes, wouldn't shift worst?
PostPosted: Thu Apr 17, 2014 8:23 pm
Banned
The ti cage is very strong. Since the photo I have cut out a lot more of the cage, just one big hole.
The titanium is very difficult to cut and drill.
I had to get some carbonite dremel bits and a carbonite m4 tap to make the threads to screw on the carbon plate. Normal dremel bits were not strong enough to do the job.
I use a downtube shifter on my front mech. Modolo,5grms. It works fine. I do have a BTP shifter as well but it was slipping a bit.
To be honest I always ride in my 53t and climb as well so I can't judge for someone who shifts front rings a lot.
The strength of the cage seems fine and is working the same as before I put the carbon plate on and dremeled out the rear.
I also have put on a plastic screw at the small end of the cage and that is holding fine as well.
:beerchug:
PostPosted: Fri Apr 18, 2014 2:17 am
Good job on the tuning, looks great
PostPosted: Fri Apr 18, 2014 11:35 pm
Make sure you post a pic of them both on the scales
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Sat Apr 19, 2014 1:29 am
exactly what I was thinking... :lol: good work though to the op..
There are no new unread posts for this topic. Specialized tarmac s-works disc couple of questions.
Naturel
Fri Mar 11, 2016 4:36 pm
mnmasotto View the latest post
There are no new unread posts for this topic. Ciamillo GSL Tuned brakes, cable insertion/clamping
Slimtim
Mon Jul 18, 2016 1:36 pm
lewolive View the latest post
There are no new unread posts for this topic. Negative GSL tuned brakes - use of padholder spacers and release lever
Slimtim
Sun Dec 11, 2016 11:32 pm
Slimtim View the latest post
There are no new unread posts for this topic. Wert parts
HaakonJohansen
9
897
Thu Sep 15, 2016 9:17 pm
mythical View the latest post
There are no new unread posts for this topic. Good Mid-level cockpit parts?
Jcgill
Tue Apr 26, 2016 11:41 am
wheelsONfire View the latest post
Users browsing this forum: Baidu [Spider], bikerjulio, campbellrae, Ltoddokc, meanmachine, micro553, nenadjev, poppiholla, superdx, Yahoo [Bot] and 29 guests
