Top Tube Crack - Super-X Hi-Mod?
tojnom
by tojnom
I was cleaning my Super-X this morning & I noticed a hairline crack in the top tube. It's right down the middle of the tube, about an inch to inch 1/2. I've never wrecked the bike, so I'm little baffled. Does this look like structural damage or just paint?
rijndael
by rijndael
I'm pretty sure I have a mold/seam line on mine, down the middle. It's been there since it was new.
Are you sure it's more than a paint crack? Mine is under the clear coat (there's no paint), and not through it.
I can take a picture of mine tonight.
tojnom
by tojnom
Yeah, if you don't mind please post a pic tonight. It's probably just a crack in the paint...I thought it was worth posting to see if anyone has had a similar experience.
emorydptt
by emorydptt
You can try and do an easy test- tap test with a nickel.
Tap the tube with the nickel and the sound should resonate instead of stop abruptly.
I would imagine if there has never trauma to the bike, then it would be non-structural.
Good luck and let us know.
my YouTube channel- keep the grams down and the watts up!
-2014 Cipollini Bond EPS | 2017 enigma echo SR11 | 2011 Time RXR ULTeam SR11 | 2010 Colnago EPS SR11 | 2013 Colnago C59 SR-EPS | 2011 Colnago Prestige Di2 | 2013 Specialized Shiv TT SWorks SR11
rijndael
by rijndael
SuperSix HiMod Evo
tojnom
by tojnom
emorydptt wrote:You can try and do an easy test- tap test with a nickel.
Nifty little trick...I think it's fine, the tone was not abrupt & it sounded similar to other areas on the top tube. In retrospect, I used a rubber mallet to push out the SI spindle ...it was stuck in the bottom bracket pretty good. Maybe the impact from the mallet caused a slight crack in the paint. Regardless, the crack seems to be superficial so all is good.
Thanks for the tip.
