It is currently Thu Dec 14, 2017 9:55 pm
PostPosted: Sun Apr 13, 2014 4:48 pm
Has anyone come up with a more straight forward application or excel sheet for comparing two frames? I realize their is the comparator excel sheet but I find it's a bit needlessly complicated and becomes difficult to decipher. Probably doesn't help im not too mathematically inclined these days.
Would be an awfully helpful\cool tool to have something a bit more simplified and visual.
I was looking to compare the Felt FC against the Specialized Tarmac in size 54 and my head gets a bit lost when starting to look at stack and reach, drop, top tube and seat tube angles.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Sun Apr 13, 2014 4:55 pm
it would be dead simple to make your own spreadsheet...
PostPosted: Sun Apr 13, 2014 5:07 pm
Easy to make a spreadsheet and compare geometry data as published, but for it to have any kind of practical use, you need to understand how those measurements were taken. Seat tube length, center-to-center, center-to-top, center-to-virtual point, virtual point-to-virtual point… same thing goes for top tube, but then you also need to take angle of seat tube and head tube in account. Head tube length, bearing-to-bearing, fork crown-to-top of top cap, etc….
In other words, just a lot of variables.
PostPosted: Sun Apr 13, 2014 5:39 pm
All good points - thanks
Just ride ..
PostPosted: Sun Apr 13, 2014 6:07 pm
Bikecad.ca
It is free, and works great. I use it frequently (and donate the developer some money from time to time because I find it a great tool).
My Bikes
My Photoblog
PostPosted: Sun Apr 13, 2014 7:02 pm
Alright that's pretty cool - ill give it a go - thanks!
Just ride ..
PostPosted: Mon Apr 14, 2014 9:59 am
With really really basic AutoCAD skills, you should be able to draw both frames and compare the differences.
I did that before, to decide if 54 or 56cm frame would be better for me.
I believe you can do the same.
My Orbea Orca
My Stava
My Instagram
PostPosted: Sun Apr 20, 2014 2:27 am
fa63 wrote:
Bikecad.ca
Thanks for the kind words and the donation. Many find the free version of BikeCAD a useful tool for comparing frame geometry. There is actually a special tool built into BikeCAD Pro that is specifically meant for this. It's called Multi-model PDF export. It's described at: bikecad.ca/multi-model_pdf
There are no new unread posts for this topic. Help with frame geometry?
angrylegs
Sun Oct 22, 2017 2:20 am
cyclenutnz View the latest post
There are no new unread posts for this topic. Attachment(s) Which other frames have the same geometry as the Colnago C60?
TonyM
16
1988
Sun Apr 16, 2017 8:57 am
AJS914 View the latest post
There are no new unread posts for this topic. Advice required regarding a geometry question.
diegogarcia
7
795
Thu Jan 19, 2017 8:54 am
diegogarcia View the latest post
There are no new unread posts for this topic. Colnago C60 vs. Pinarello F10 (or F8): geometry & sizing?
TonyM
20
1809
Fri Oct 27, 2017 4:34 am
TonyM View the latest post
There are no new unread posts for this topic. Colnago Traditional Geometry Question
Mr.Gib
15
1793
Mon Feb 13, 2017 1:50 pm
BdaGhisallo View the latest post
Users browsing this forum: Baidu [Spider], baldy, BdaGhisallo, beanbiken, GothicCastle and 38 guests
