It is currently Fri Jan 19, 2018 1:02 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: SRAM Force BB30 question
PostPosted: Sat Apr 12, 2014 7:02 pm
I have a '12 Cannondale Supersix 4 with SRAM Force BB30 crankset.
Yesterday I lubed my BB30 bearings, cleaned everything, applied some clean grease and assembled the crankset.
Today I took my bike for a spin. At first I thought it's all in my head, but when I stopped to check, the crankset had a pretty big lateral play.
The hex screw seems to be bottomed out.
I have a metal bearing cover on the DS, which slides on the spindle
no spacers on the NDS
a bearing cover on the NDS
and a bearing without a cover on the DS
I am 99% certain that I didn't lose any spacer while cleaning it.
Am I doing something wrong or did I lose something?
Thanks for your help!
PostPosted: Sat Apr 12, 2014 10:10 pm
You are missing spacers and a wavy washer on the nds.
My RCA
PostPosted: Sun Apr 13, 2014 1:55 am
You're just missing shim washers. If u really want it spot on, determine the gap & spacers required using a feeler gauge (available at any tool or auto shop). btw, how do you lube a sealed cartridge bearing?
PostPosted: Sun Apr 13, 2014 3:36 am
You need a wavy washer too. Not just the spacers.
My RCA
 Post subject:
PostPosted: Sun Apr 13, 2014 4:00 am
 Post subject: Re:
PostPosted: Sun Apr 13, 2014 7:59 am
Causidicus wrote:
farva wrote:
...how do you lube a sealed cartridge bearing?
Use a fine pointed tool to carefully get under and then gently pry up, then lift out the seal. Then clean and relube with whatever grease takes your fancy. The seal can be reinstalled by hand and fingernail with a bit of dexterity and pressure. Be carful not to damage the lip seal and it's hard to go wrong.
Yeap! That's exactly what I did.
PostPosted: Sun Apr 13, 2014 2:12 pm
Hmmm maybe I'll give that a try.
I've always treated them as remove & replace
PostPosted: Thu May 15, 2014 9:18 am
Solved my problem with the wavy washer and some transparent spacers. Thanks for your help!
PostPosted: Thu May 15, 2014 12:07 pm
Next time, read this : SRAM service manual
Came in really handy when I serviced my PF30 bottom bracket.
There are no new unread posts for this topic. BB30 : Sram + fsa compatibilty?
alcatraz
Fri Jul 28, 2017 3:18 am
CycloTron View the latest post
There are no new unread posts for this topic. Help with Sram Red/Force RD
Hardstyle
Mon Jul 10, 2017 12:04 am
Hardstyle View the latest post
There are no new unread posts for this topic. Attachment(s) Sram Red BB30 cranks & BB30A
meanmachine
7
2480
Mon Apr 03, 2017 5:08 pm
Valbrona View the latest post
There are no new unread posts for this topic. SRAM Force 22 vs Red 22 shifters
loudtiger
10
999
Mon Aug 14, 2017 4:07 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. SRAM Long-Pin/GXP and Short-Pin/BB30 Chainrings
Valbrona
Sat Jan 21, 2017 3:21 pm
darnellrm View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, ghostryder, Imaking20 and 33 guests
