2011 BMC SLR01 bottom bracket bb30 - 42 or 46mm?
critracer26
by critracer26
I am thinking of getting a used 2011 BMC SLR01 and am pricing out how much it would cost to swap frames. PBK.com is asking me if i want 42mm or 46mm ultra torque cups? anyone know which are proper for that frame set? currently running chorus 10 cranks...
-David
deltree
by deltree
Well that frameset should be BB30 so you'll need the 42mm ones (IIRC the 46 is for PF30). However I had a 2011 SLR01 which came from the factory with a BSA threaded adapter pressed in. So I would double check to make sure it hasn't got one of those.
