It is currently Fri Feb 24, 2017 12:07 pm
PostPosted: Mon Apr 07, 2014 5:12 pm
I am in the market to change my current road bike and found a 2010 Focus Izalco extreme running Campy SR and the stock Mavic SLR clinchers.
Bike is in super pristine condition and i am seriously thinking of closing the deal.
I only have one thing that bothers me... The frame has an integrated seatpost and it seems it has been cut a bit lower than what would fit me. Do you know how much i can raise the seat without affecting the riding characteristics of the frame? Is there any adapter that i can use between the seat and the post that could give me an extra cm? Maybe i do not even need teh extra length, but i would like to know once i put my hands on the bike, as i only want to go there once and close the deal.
Thanks for your help...
PS: as it is weight weenies here, do you know what kind of weight i should expect from that bike?
PostPosted: Tue Apr 08, 2014 12:40 am
Do you know your BB - Saddle/Saddle Rail height? I am confused when you say it 'seems' to have been cut a bit lower, is that just through eyeballing a picture or measurements?
If you do need to raise the saddle height there are a couple of options - find a saddle with a taller rail and therefore overall height to make up the difference (even padding can affect a saddle height) good if its a small distance off being the correct height. Or alternatively depending on the seatpost diameter you can use an ISP topper that allows for shimming FSA make a couple of options.
Good Luck
PostPosted: Tue Apr 08, 2014 1:58 am
Normal seatpost toppers usually have 15-20mm of adjustment. KCNC make a 120mm version that has about 60-70mm depending on offset. I'm not sure about the OD of the mast though. Search the forums I'm sure plenty of people have had one of those here.
PostPosted: Tue Apr 08, 2014 2:01 am
My topper is also of this basic type, and in the case of my arrangement is sits against the very top edge of the seat tube. However, they are supposed to allow of the order of 2-3cm up or down movement, but I have never tested this claim in practice. My guess is that you might get some slippage, even if you rough up the tube and use carbon paste.
PostPosted: Tue Apr 08, 2014 2:09 am
Yep, that's why it's always a good idea to keep the excess that's cut off the mast. That way you can cut that waste piece down and use it as a shim to avoid slippage.
PostPosted: Tue Apr 08, 2014 8:33 pm
Thanks for the replies guys.
I decided to act first, think later and got the bike.
Love the frame colours and the design. :D
Haven't had the time to ride it yet, but hope thats gonna happen soon.
Crappy phone pic below
Cheers! :beerchug:
PostPosted: Tue Apr 08, 2014 8:50 pm
what size frame is that? Looks like 72-73cm BB-top of saddle no? Also what's the weight?
PostPosted: Tue Apr 08, 2014 8:53 pm
bb-top το saddle is 75cm.
The frame is a size L
don't know weight yet :(
There are no new unread posts for this topic. Focus Izalco Max available as a frameset? Geometry?
KH
9
1025
Mon Mar 21, 2016 12:01 am
reedplayer View the latest post
There are no new unread posts for this topic. Hollowgram SISL chainset on new PF30 Focus Izalco Max?
KH
Thu Apr 14, 2016 7:00 pm
ms6073 View the latest post
There are no new unread posts for this topic. Focus RAT + Tacx Neo?
the_marsbar
Wed Dec 07, 2016 8:32 pm
the_marsbar View the latest post
There are no new unread posts for this topic. Northwave Extreme RR shoes 2017
dolophonic
Wed Jan 25, 2017 1:39 pm
mrgray View the latest post
There are no new unread posts for this topic. Cervelo S2 2009/2010 or R3 2013?
KAoslo
11
1039
Wed Jun 01, 2016 10:33 am
clm2206 View the latest post
Users browsing this forum: Calvaroz, EvilEuro, Google Adsense [Bot], Orlok, raisinberry777 and 37 guests
