It is currently Wed Mar 01, 2017 9:41 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Thu Apr 03, 2014 6:21 pm
Is the KCNC titanium shift cable head Camapgnolo (Ultrashift) compatible?
I've never been happy with Campagnolo right shift cable life, my first cable was even shorter lived after I upgraded to Ultrashift, and the superior fatigue characteristics of titanium are attractive.
PostPosted: Wed Apr 09, 2014 12:36 am
I think the KCNC Ti gear cables come with adapters that support both Campy and Shimano shifters. In my experience, the Ti cables shifted poorly because of stretch. The brake cables were also quite terrible for the same reason. I could pull my brake lever all the way back until it hit the bar. Stainless cables in the same housings did not do that.
PostPosted: Thu Apr 10, 2014 2:11 am
I think you need to redo your cable setup. I am using them on two bikes with no issues whatsoever. They work identical to standard steel cables but much lighter.
PostPosted: Thu Apr 10, 2014 3:38 am
Drew the Ti cables should work for you. I would not do it for superior cable-life though. The teflon coating is pretty delicate.
Re: tantra comments, ignore them, it is universally acknowledged that his was a set-up issue. I have over 6,000k on my set, braking and shifting are perfect (SRAM Red).
I am pretty sure any brake cable stretch would have been identified after descending almost 9000 vertical metres yesterday.
http://app.strava.com/activities/128428512
http://app.strava.com/activities/128429359
Evo 5.63kg SL3 6.66 viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
There are no new unread posts for this topic. Shimano Brake Cable in Campagnolo Ultra-Shift Housing?
Valbrona
Thu Jan 05, 2017 11:05 pm
Valbrona View the latest post
There are no new unread posts for this topic. 34/52T Campagnolo shift quality?
RedRacer
Tue Sep 06, 2016 5:51 am
Kurets View the latest post
There are no new unread posts for this topic. Help! Campagnolo Record 11 crank ghost shift in small-small combo
Birdman
23
1241
Thu Jul 21, 2016 5:37 pm
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo 2015 UT / Italian threaded BB / Titanium frame - best practice
mriddle
16
1280
Sat Jul 30, 2016 1:54 pm
mriddle View the latest post
There are no new unread posts for this topic. Scott Addict SL Cable Stops for internal cable routing
kulivontot
Sat Sep 10, 2016 4:33 am
kulivontot View the latest post
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], ms6073, tuba, Xico and 42 guests
