New Shimano Di2 D-FLY Box vs 5 Port Front Junction
morrisond
by morrisond
It's not new news - but doesn't the 5 port Front Junction box which according to Shimano's website has wireless functionality do the same as this?
http://www.bikerumor.com/2014/02/02/shi ... computers/
Or did Shimano change there minds on the wireless transmission protocol and the 5 port has some Standard that was only going to work with the non-existant Flight Deck?
Nebby
by Nebby
morrisond wrote:It's not new news - but doesn't the 5 port Front Junction box which according to Shimano's website has wireless functionality do the same as this?
Do you have a link for the mention of the wireless functionality? IIRC, it was originally advertised to have that, but around the time when it was actually released they stopped mentioning it completely in their press releases/marketing material. At the time it was assumed that they had pulled the support for it and/or removed the wireless hardware.
morrisond
by morrisond
Taken directly from the Shimano website - Look at the bottom
Electronic
DA 9000 Series
Dual Control Lever
ST-9070
State of the art Di2 electronic technology for instant, accurate shifts first time, every time, at the push of a button. Now 11-speed compatible, with enhanced feedback and improved ergonomics for easier access to the shift buttons from the top of the the hoods. Cleaner wiring thanks to single-wire E-tube connections, that also make it easy to add satellite shifters for bar tops or in the drops.
11-speed compatible
Improved ergonomics
Enhanced feedback
Rear derailleur
RD-9070
Precise, lightning-fast shifts across an 11-speed cassette, whatever the conditions, with just a button click. The 9070 rear derailleur is now more compact and lighter, with E-tube connection to simplify installation. And automatic crash protection moves the cage out of harm's way.
11-speed design
Automatic crash protection
Maximum sprocket 28T
Compact, lightweight body
Front derailleur
FD-9070
Precision actuators move the cage swiftly and smoothly for fast, silent, accurate front shifts every time. And with single-wire E-tube connection to the rest of the system, the front derailleur is able to automatically trim itself as you shift the rear derailleur, eliminating chain rub.
Fast, precise, smooth shifting
Automatic trimming
Battery/wiring/accessories
The lithium-ion battery is now available in two versions, suitable for both external and concealed internal mounting. A single-wire E-tube connection and new junction units for a cleaner look and easier installation.
Long battery life (up to 2000km when fully charged)
Available for external or concealed mounting
Electric wires (EW-SD50) available in a range lengths from 150mm to 1400mm
3 and 5 port junctions for cockpit area available. 5-port includes wireless unit
Special PC interface (SM-PCE1) for system diagnostics and customising the system
Nebby
by Nebby
Time to ask a shimano rep, because obviously they haven't given much detail on the 5-port junction box. I'd suspect that is just a remnant of when it was an advertised feature to work with the flight deck. Wonder if the wireless hardware is even in there...
TurboKoo
by TurboKoo
5-port doesn't include wireless unit. At least not mine. I have ISMEWW011 to get info to PRO scio computer.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
Nebby
by Nebby
In case anyone was still wondering, I got a response from the Shimano tech rep via my LBS:
"The 5 port junction A does not have wireless capabilities. It was originally going to but that function was pulled before it was released. The new D Fly unit will transmit gear indicator and battery life indicator to a compatible computer."
