It is currently Tue Jan 23, 2018 1:01 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Fri Apr 04, 2014 3:50 am
I concur the record chain is excellent, and the rings are explicitly compatible with them... Just thought it's worth a shot as far as trouble-shooting to see if that changes things.
Also may be worth making sure that the derailleur is low enough and that it's at a good angle front-to-back (not side to side) which would be a feature of the frame... e.g. close to the rings towards the front of bike, but large gap at the tail of derailleur - this is unlikely to be a factor, but sometimes is on Compact setups...
Just guessing at this point though. Good luck!!
 Post subject:
PostPosted: Fri Apr 04, 2014 3:53 am
PostPosted: Sat Apr 05, 2014 4:14 pm
Hi folks...Adam from Praxis here.
This thread came up on my radar and I wanted to reach out.
We have a huge amount of customers with this exact setup and loving it, so I'm interested in what the possible issue is also.
Our rings on a Quarq (new and old Quarq) with Campy 11 has actually become a very common setup we've been helping people with.
One simple first fast step would be to please check the mounting. Believe it our not, we actually find that many have actually mounted our inner rings in the wrong timing position and also many times flipped the wrong way. Both of these will completely mess up the shifting.
This is one of our #1 calls/emails and is quickly fixed.
We're soon adding/updating the ring markings to make it less likely that someone accidentally mount them wrong.
Here is our mounting guide to follow - http://www.praxiscycles.com/wp-content/ ... unting.jpg
Other than checking that, like you guys mentioned in this thread...I'm very curious about the chain, the FD setup and the FD mount/braze on as we come across flexy mounts with frequency also.
Anyway...we're shifting geeks and just want to help out. So by all means email or call us and we'll for sure try and help shake down the potential issue.
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz, CA
www.praxis-works.com
PostPosted: Tue Apr 08, 2014 4:29 am
the rings are indeed mounted correctly. i have sent pictures to Praxis customer service when they were first warranted to confirm this. i have had 3 different mechanics look at the FD and try as they might to get it to work without success.
crankset is Quarq Riken 170 53/39
chain is Campagnolo Record 11
1st bike was a Cannondale Evo with a Braze-On mount
2nd Bike is a Litespeed C1R with Braze-On mount.
this is my second set of rings, and although it works better than the first set, they are far from what i was expecting as far as shift quality. sometimes the chain will refuse to go from the 39 to the 53 unless i drop down a gear or 2 in the rear, shift back to the 39, and then shift again to the 53. i'm not impressed at all.
PostPosted: Thu Jul 24, 2014 10:53 pm
I have bb30 Quarq Riken (with Omnical). The shifting with my 10spd Force is problematic,the chain is having a really hard time to shift from small to big gear (front).
Changed to Praxxis Works and it became much worst! Changed to SRAM Red (hidden bolt) and it perform magically perfect.
PostPosted: Fri Jul 25, 2014 5:41 am
if the chain is having trouble to go from 39 to 53, why not just loosen the outer limiting screw on FD and increase abit cable tension. This ensures the FD goes the extra miles to bring the chain up to 53. Granted you won't be able to cross chain as much as before, but i remember campy have great FD trim feature.
PostPosted: Fri Jul 25, 2014 11:25 am
Parxis (52/36)/KMC X11SL chain/Quarq SRAM Red/SR EPS on my wife's Parlee Z5 SLi. Shifts like a dream!
PostPosted: Fri Jul 25, 2014 1:01 pm
The solution to your problems does not lie in purchasing more parts. You need to have your existing parts adjusted by a person who knows what they're doing. I suggest that whomever has tuned your front derailleur doesn't know what they're doing.
PostPosted: Fri Jul 25, 2014 1:10 pm
Just to add another success Story.. after continous chain drops (switched chains, added k-edge) I mounted Praxis Rings on my EVO. No drops since then (did the last two races with this setup), and smooth effortless shifting.
Setup: Supersix EVO, Quarq Elsa, Campagnolo Super Record, KMC X11 SL..
Supersix HiMod, Supersix EVO HiMod, Crux, CaadX, Lynskey R330 & Pro29, Yelli Screamy 29
PostPosted: Fri Jul 25, 2014 1:25 pm
No issuses here.. :smartass:
PostPosted: Thu Apr 02, 2015 5:13 am
to follow this up - a quick summary:
Canondale Evo new build with Record 11 group and Quarq Riken with Praxis 53/39 rings
The shift from the 39 to 53 is random- sometimes it works, other times I have to shift and re-shift 3-4 times to get it to catch
Check ring positioning and FD adjustment with 5 different mechanics- everything checks out
Praxis warranties rings, new rings mounted
Same issue, nothing changes despite numerous mechanics trying to adjust FD
I live with bad shifting for a year
The following year, I swapped my group over to a new Litespeed C1R. Same issue- 39 to 53 is intermittent
I swap FD from Record to Chorus hoping the metal Chorus FD will be stiffer and improve shifting. Does not work any better
Numerous mechanics try and fail to tweak FD to make it work
Finally, left shifter goes south. I replaced the mechanicals and when remounted, I found that my FD shifting issues were cured.
As it turns out, the problem all along was that I received a faulty Record shifter from Campagnolo right out of the box.
Problem solved, but i have to live through 2 years of bad shifting and $$$ trying to fix it. I wish I could have diagnosed this and gotten the shifter warrantied.
thanks for all the advice here.
PostPosted: Thu Apr 02, 2015 9:31 am
Well, I guess all there is to say is at least it's working now! Sorry it was such a pain.
"Deserve's got nothing to do with it." William Munny
PostPosted: Thu Apr 02, 2015 9:54 am
Confirms Praxis wasn't at fault, great stuff.
This kind of topic could make unfair bad publicity for them.
Well, they're enough praised anywhere else to counter balance but..
PostPosted: Thu Apr 02, 2015 1:10 pm
Yes, this is why I typed a follow up to this to close the case!
There are no new unread posts for this topic. Praxis Works chainring bolt torque spec
SpecializedColnago
Sat Feb 18, 2017 6:13 am
sp3000 View the latest post
There are no new unread posts for this topic. What bottom bracket works for a QUARQ DFOUR91 on Cannondale SuperSix Evo 2015?
kode54
Mon Dec 04, 2017 9:18 am
savechief View the latest post
There are no new unread posts for this topic. Quarq Dzero w. Campagnolo, chainline question
r4nd0mv4r14bl3
Sun Jan 21, 2018 5:20 pm
moonoi View the latest post
There are no new unread posts for this topic. Help: Bearing removal on Praxis BSA 30 (M30 BB)
taylorpetie
Sun Sep 03, 2017 1:36 pm
alcatraz View the latest post
There are no new unread posts for this topic. Praxis Zayante Crankset - BB compatibility
Stolichnaya
Sun Aug 27, 2017 1:14 pm
Attermann View the latest post
Users browsing this forum: CarlosFerreiro, jwalther, morganb, zirxo and 27 guests
