It is currently Tue Oct 17, 2017 3:48 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sat Mar 29, 2014 7:58 pm
Hi,
I have been using the sram red 2012 for quite some time now. It keeps making a screeching noise during descent. I have tried changing the brake pads to so many different types, from corima brake pads to the one i am using right now, the swissstop black prince. It is better now, but it still makes a loud screeching noise after a while on the descent. The wheels that i am using is the zipp 303 firecrest CC.
So, the question is what makes the noise? What should i do to make it go away. Or is it better for me to change the brakes to TRP 970?
Thanks
Sent from my iPad using Tapatalk HD
PostPosted: Sat Mar 29, 2014 8:40 pm
Try the Zipp pads. And then toe them in.
The easiest way to do that is to place a business card between the pad and rim, just at the leading edge of the rim (which is end towards the back of the bike for the normal set stay and fork brake placement). Clamp the brake lever down with one hand, then loosen the nut that holds the pad to the caliper arm and tighten it again. You may need to tighten it just enough to get it to hold position then release the brake so you can use your other hand to hold the pad so it does not rotate.
Then do the other side.
PostPosted: Sun Mar 30, 2014 1:51 am
Lubing the bolts/washers that hold the pads on works wonders for keeping the pads in place while tightening. Last time I adjusted my pads I tried tightening first before lubing, and then again after lubing. It went from impossible to keep aligned even while holding them with my hand, to easy to keep them aligned all the way to full tension without touching them directly (only putting pressure on the brake lever).
PostPosted: Sun Mar 30, 2014 3:12 pm
Thanks! I'll try that.
PostPosted: Wed Apr 02, 2014 5:43 am
I had a similar problem when I switched to different wheels. No amount of toe-in would get rid of the problem. It seems to develop on long fast descents when the brakes get very hot. I think the pads are simply getting too hot and they get more "grabby", causing them to vibrate and squeal.
The solution for me was cork pads. No more squeal :D
PostPosted: Wed Apr 02, 2014 2:23 pm
Careful- using the wrong pads can ruin carbon rims and that's usually not covered by the rim maker's warranty.
PostPosted: Thu Apr 03, 2014 3:37 am
I didn't say anything about using the wrong pads. Use pads that are carbon specific and ones that haven't been previously used on an aluminum rim. Go to http://www.zipp.com/support/maintenance/brakepads.php to get a list of approved pads. Note that there are two kinds of cork pads listed. I've had success with the Bontrager ones.
There are no new unread posts for this topic. Chain Ring bolt stripped. Creaking noises. Recommendations?
Lightweenie
7
564
Tue Sep 12, 2017 7:26 am
Lightweenie View the latest post
There are no new unread posts for this topic. Attachment(s) NEW THM-CARBONES FIBULA BRAKESET
[ Go to page: 1 2 3 4 5 ]
minimini
62
7268
Fri Oct 06, 2017 6:20 am
mrgray View the latest post
There are no new unread posts for this topic. Anyone still making Aero Gloves?
520 Dan
9
1312
Sun Nov 06, 2016 6:29 pm
cyclespeed View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
Shrike
70
9156
Sat Apr 08, 2017 10:20 am
JackRussellRacing View the latest post
There are no new unread posts for this topic. Upgrade Or Keep: 2012 Cannondale Evo HiMod
SBRYYC
14
2369
Fri Aug 11, 2017 12:30 pm
tarmackev View the latest post
Users browsing this forum: axiom, Monkeyfudger, nestornnk, phunky, tommasini and 24 guests
