which brand of inner tube are you rocking?
jpanspac
by jpanspac
Uh oh. I was thinking of trying latex tubes with my Enve wheels. 95% of my riding is on flat land. If I don't brake going downhill would I be ok?
My favorite components are the ones I never have to think about.
mallardducks
by mallardducks
Vittoria ultralites for all training wheels, any lighter butyl tube is too prone to punctures for me + it's easy to get ultralites mail order for $2.50/tube - which is about half the price of el cheapo budget tubes at any lbs up in our neck of the woods.
My race tubulars are obviously lightweight latex... personally I wouldn't ride a lightweight latex tube in anything other than a race because flatting is just too much of a PITA for me, as is pumping tires every day.
veloflyte
by veloflyte
rg255 wrote:I've had bad experience with Specialized inner tubes, had three valves (the screw valve tip in the top of the presta valve bent/snapped out) never had this problem with Conti's (they're not the lightest around but they are seemingly reliable - had one on about 3 years without a single flat or fault). They are the only two manufacturers available to me locally although I did notice someone stocking Michelin the other day.
As a mechanic for many years, I can definitely confirm the frequent problems with Specialized's ultra light weight butyl tubes. They were frequently bad right out of the box....about 1 in 10 tubes had holes in them that would let all the air out in about 2-3 days. They held on inflation. But they were simply too thin.
Juanmoretime
Administrator
by Juanmoretime
Madcow, why do you say latex cannot be used in a carbon rim? I've been doing it for over 4 years and have enjoyed the least amount of flats in the same time period compared to riding light butyl tubes and road many brands of light butyl tubes with the same results, frequent flats.
RESIDENT GRUMPY OLD MAN.
Frankie - B
Administrator
by Frankie - B
Carbon rims have a hard time dissipating heat. A latex inner tube is known to pop when used in Carbon Clinchers, probably because they are so flexible.
If you live in the flats, you can get away with carbon clinchers and latex inner tubes, because you don't brake for longer periods of time, like in a decent.
hence, less heat build up.
Oh, and I use Michelin latex in my alloy clinchers and Challenge latex in my carbon clinchers.
adry85
by adry85
schwalbe ultralight, 65grams declared..i use this about 8 months, no pun
Inviato dal mio iPhone utilizzando Tapatalk
Using Tapatalk
savechief
by savechief
Fyi, for those looking for the Panaracer R'Air tubes, Ribble has them for about $11 each. Expensive, but less than I've seen them other places.
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
WMW
by WMW
savechief wrote:Fyi, for those looking for the Panaracer R'Air tubes, Ribble has them for about $11 each. Expensive, but less than I've seen them other places.
They are just butyl tubes... I'm not seeing it.
I bought Vittoria latex from Ribble for $8 each.
formerly rruff...
ToffieBoi
by ToffieBoi
Schwalbe SV20. 65grams and accepts 25C tires.
With Continental GrandPrix 24C tires, I got only one puncture and it was from inside the rim. A really really small hole. I don't know what caused it, but it was totally flat after 3 days of not riding.
Self adhesive Zefal patch was great to fix it.
I am carrying regular heavy inner tubes with me during ride.
I also have 2 extra Specialized Turbo Ultralight tubes, 65gram ones again, pre-talced.
If I will have a few more punctures, I will try them.
edit: I am riding 23mm wide wheels and 24mm wide tire. 25mm wide measured.
Stats
by Stats
Continental race lights for me, different valve stem lengths for front and rear work well.
