It is currently Tue Jan 23, 2018 11:18 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Tue Mar 25, 2014 4:13 pm
I'm new in the TTing, and have an option to choose Deda Parabolica Zero (straight) or Deda Parabolica Due (S-bend) clip-on aerobars. I need them for short to mid length time trials. What do You suggest?
Thanks!
PostPosted: Tue Mar 25, 2014 10:26 pm
I have had the straight ones in the past, which I ended up selling as they did put too much strain on my wrists to be comfortable even for really short TTs. Perhaps not only the fault of the aerobars as I already have damaged wrists from crashes in the past, so your mileage may vary.
The Deda Parabolicas are entry level aerobars and offer limited adjustability like other aerobars in the same price range. Pads goes left/right + fore/aft & extensions lengthwise. Thats about what you can do with them. I really missed having pad height adjustment (stack) in relation to the extensions. Perhaps this could be solved with some some nuts, washers and longer bolts.
The pads that are delivered with the Parabolicas are way too thin for my taste. Also the extensions are not pre-drilled for internal routing, so expect to bring out the drill if you want to keep your cables neat.
My suggestion is the PRO Synop extensions which I have tried and works great: http://www.wiggle.co.uk/pro-synop-tt-ba ... -aerobars/
PostPosted: Tue Mar 25, 2014 11:11 pm
I had the s bend version and they put my wrists at an angle that was comfortable. I would imagine the straight versions wouldn't be very comfortable. I don't imagine the angle of your wrists would affect aerodynamics very much. I know a lot of guys who are winning TT's on ski slope extensions so I'd say comfort would probably be of more importance even for short races.
There are no new unread posts for this topic. Quick question: Are Deda 31.7mm bars OK with non Deda stems?
hannawald
Fri Oct 20, 2017 10:41 pm
hannawald View the latest post
There are no new unread posts for this topic. Fetha for S-Series aerobars
Shrike
Fri Mar 17, 2017 11:59 am
mrlobber View the latest post
There are no new unread posts for this topic. Attachment(s) Front Light for Aerobars?
jimaizumi
9
337
Tue Jan 23, 2018 10:02 am
MayhemSWE View the latest post
There are no new unread posts for this topic. Favorite bar tape for aerobars
Kurets
Sat Jul 08, 2017 11:34 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Got aerobars and wahoo elemet uhmm is there a mount
bm0p700f
9
906
Thu Jun 22, 2017 9:18 am
quango2k View the latest post
Users browsing this forum: BdaGhisallo, Bing [Bot], Google [Bot], jacobeh, jekyll man, joejack951, Kaboom, madik, raisinberry777, wobbly and 39 guests
