Selle Italia SLR Flow carbonio issue or ok?
aspms
by aspms
So I have had older model of this SLR carbonio (non Flow) on my previous xc bikes which has tight joints between rails and surface and now I got one for road bike as well, but it's Flow version and newer model which have different rail connection in front.
Should this joint be completely tight or there should be tiny movement when saddle flexes?
by 5 8 5
Got an SLR Team with the same rails. That area is filled in, no movement there.
aspms
by aspms
Thanks for info. Actually it doesn't move that noticeable, but when I try to twist the rails or flex the saddle surface it tends to creak from that connection.
I guess it's not filled enough- will see our local carbon guru tomorrow, hopefully can fix it with some epoxy or something.
jimborello
by jimborello
Mine had the same issue and broke when I passed over a speed bump. It was replaced under warranty but dont use it like that, make sure to fix it if it is not covered by warranty anymore.
makoti
by makoti
I was planning on getting one of these. Any chance you could post a close-up pic of the two saddles so I can see what we are talking about? Or at least of this one?
Thanks. Too pricey to buy stuff that is showing up with QC issues...
aspms
by aspms
Flow version is current SLR model and the other one is previous model:
Image Image
You can see that current model doesn't have much space in there to fill with epoxy. Also newer model rails coming to front nose are much thinner and flow saddle's surface flexes more itself so there is more chance for this connection to come loose.
Image Image
The older SLR has been abused on my XC bikes for 3 years now and still does it's job perfectly.
Oswald
by Oswald
My 2014 SLR Team also has a gap at the same spot. I was slightly concerned, but haven't noticed any creaking so far. But I've only done 2 rides on it so far.
makoti
by makoti
Thanks for the pics!
aspms
by aspms
Got it fixed by our carbon guru- filled with very fine epoxy. No more creaking and feels really solid now.
