It is currently Mon Jan 22, 2018 11:14 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Mar 21, 2014 9:41 am
Got my foil yesterday, delighted but need a little help.
As this is my first build does anyone have a step by step guide for installing the headset and fork (what is the order of bearings etc, what is greased, what way do the tapers go on bearings etc)?
I notice there is no crown race for the base of the steerer tube, the bearing just sits on this. Is this correct?
PostPosted: Fri Mar 21, 2014 10:55 am
Hi, had similar questions when I built mine.
Here is the picture from a manual I sourced from Scott
And you are correct about there being no crown race.
PostPosted: Fri Mar 21, 2014 11:54 am
I dont think so. I have a component that looks like one but it doesnt seem to fit the whole way down. It an aluminium ring with a couple of ridges around it and a apered end. There is a vertical slot cut into it. Maybe this is the race and I just need to force it down a little more.
Thanks for the picture, would you happen to have a copy of the manual in PDF?
PostPosted: Fri Mar 21, 2014 1:28 pm
That ring goes on top of the upper bearing, ridge down. Slot to the left or right, not in front or back. Its the compression ring that forces the upper bearing into alignment as you preload it.
My RCA
PostPosted: Fri Mar 21, 2014 1:43 pm
I since spoke with a mechanic in Westbrook cyles where I bought it (superb service by the way) and they calrified the crown race is built into the fork so I think I am good to go. Thanks for the help.
PostPosted: Tue Jun 16, 2015 9:22 pm
I know this is an old thread, but can anyone confirm whether the upper bearing sits directly into the frame onto the carbon? Or is there some insert that the bearing sits in?
www.flickr.com/carlos_the_great
PostPosted: Wed Jun 17, 2015 3:52 am
Carbon
AX Lightness Vial Evo, Carl Strong Titanium
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6922
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott Foil HMF Build
ab01ns
Sat Dec 16, 2017 5:30 pm
banik69 View the latest post
There are no new unread posts for this topic. 2018 Scott Foil disc
Renne
13
2808
Fri Oct 06, 2017 7:44 pm
TonyM View the latest post
There are no new unread posts for this topic. Please help with scott foil model year
kelih
Fri Jun 23, 2017 3:11 pm
kelih View the latest post
There are no new unread posts for this topic. Scott foil frame finish
toastie
Mon Apr 03, 2017 6:18 pm
toastie View the latest post
Users browsing this forum: Bing [Bot], Chris3g, dricked, JoshMA87, Miller, silvalis, Wookski, zappafile123 and 53 guests
