It is currently Fri Dec 15, 2017 7:10 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sat Mar 15, 2014 9:31 am
Somebody help me please!
I have searched, and searched and searched, but cannot find what I am looking for anywhere!!
I would like to buy some headset bearing top covers, the bit above the headset and beneath the stem.
My current covers on both my TCR's are nigh on 10mm and I want to go lower on the front.
If anyone has any idea where I can find said covers, PLEASE let me know.
I can find plenty of 1 1/8" covers, but these need to be 1 1/4".
Preferably 5mm or less.
Many thanks.
'17 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'15 Cannondale Super Six Evo HM - DA9000- DA9000 SRM - CC40C
'13 Giant Trinity Composite - U6800 - QuarQ DZero
PostPosted: Sat Mar 15, 2014 11:18 am
Hi,
Won't be an easy search, maybe canyon can help you out (ps. if the outer diameter is ok it wont be too hard to dremel the inside to 1 1/4")
PostPosted: Sat Mar 15, 2014 11:52 pm
I'll get in touch with them. Thanks.
PostPosted: Sun Mar 16, 2014 2:24 am
ebay is a good source
http://www.ebay.com.au/itm/NEW-GIANT-1- ... 1335415028
PostPosted: Sun Mar 16, 2014 9:34 am
They are spacers
I am looking for headset top covers
Thanks though.
PostPosted: Sun Mar 16, 2014 10:58 am
Stoo, don't you need a headset cover going from 1 1/4 to 1 1/8?
Your forks tube and your stem are probably 1 1/8 ?
In any case something like this one?
Damn, omitted to save the link :x
Anyway , DiaCompe has a 1 1/4 headset cover.
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Sun Mar 16, 2014 11:34 am
Stoo wrote:
They are spacers
Thanks though.
Sorry was a bit confused, normally to lower a stem, you reduce spacers from under the stem and put them on top of the stem and reuse the top cap. Once you decide the stem height is correct you cut the steerer tube, getting rid of the spacers on top of the stem.
PostPosted: Mon Mar 17, 2014 12:00 am
Lannes, yeah I know buddy :)
I have the stem as low as it will go and want to go lower.
Only option is to reduce the height of the headset cover.
I only want another 5mm or so.
Bura, Giants OD2 system is a 1 1/2" crown reducing to 1 1/4" at the stem.
I'll have a look at diacompe though. Thanks
PostPosted: Mon Mar 17, 2014 4:16 pm
OK, found.
Canyon do a top cap for the ultimate series that it 1.25" ID.
4.75mm height.
£20.95 plus postage however!!
https://www.canyon.com/_en/shop/?catego ... item=35557
PostPosted: Tue Mar 17, 2015 3:51 am
I got one for my Propel here
http://veloflyte.com/veloflyte_componen ... st_shields
PostPosted: Tue Mar 17, 2015 10:15 pm
http://www.cobbcycling.com/shop/accesso ... m-top-caps
There are no new unread posts for this topic. Help with finding a replacement Canyon lower headset bearing
jimwhimpey
Tue Oct 03, 2017 9:43 pm
jfranci3 View the latest post
There are no new unread posts for this topic. Giant OD2 headset weight savings
haynesdavid1988
Thu Jun 22, 2017 3:18 am
haynesdavid1988 View the latest post
There are no new unread posts for this topic. Help: Bearing removal on Praxis BSA 30 (M30 BB)
taylorpetie
Sun Sep 03, 2017 1:36 pm
alcatraz View the latest post
There are no new unread posts for this topic. GXP Bottom Bracket with 24mm NDS Bearing?
johng650
11
804
Tue Mar 21, 2017 1:47 pm
bikerjulio View the latest post
There are no new unread posts for this topic. BMC teammachine lower bearing spec?
xcnick
Sun Nov 12, 2017 4:28 pm
xcnick View the latest post
Users browsing this forum: dereksmalls, jmagoulas, kookie, PinaF8, rsantos450, siim, zoki76 and 38 guests
