It is currently Thu Jan 18, 2018 9:15 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
 Post subject: Fizik Antares options
PostPosted: Fri Mar 14, 2014 9:34 pm
Hi all.
After quickly trying a Fizik Antares on today's 30 miler I'm hopeful that this may be THE saddle for me.
I bought a cheap manganese version as I was just trying it out, but it's 80g heavier than the Toupe pro that I have been using. So ideally I'd like to get hold of a lighter version if it's still looking good after a few weeks trial.
So, does anyone know if there are any differences between all the different models (expect weight of course). Ie does the carbon railed version ride different to the Kium? Are the wingflex sides on the new R1 and R3 worthwhile? What about the 00? Is it worth that price tag?
Any help greatly appreciated.
Cheers
PostPosted: Fri Mar 14, 2014 10:01 pm
viewtopic.php?f=3&t=91817
viewtopic.php?f=3&t=105177
PostPosted: Fri Mar 14, 2014 10:10 pm
Thanks! :oops:
PostPosted: Fri Mar 14, 2014 10:12 pm
I own the 00 and i can say that it's quite comfortable and so far I have no complaints. For the weight it really does have a surprising amount of padding. I'm not sure if the lack of a channel in the center would bother you, but all I know about the difference between the 00 and the other antares models is that it is a little stiffer due to the shell design.
PostPosted: Sat Mar 15, 2014 1:03 am
Thanks for the info Jason.
I have been using the Toupe for the last few years, so I thought the lack of channel would be an issue for me, but after over 1:30 today I had no issues with numbness. I did try and Arione a number of years ago and that was definatley a no no for me. I've been having problems with the Toupe recently as I've upped my mileage which I think is linked to the amount of pressure on the sit bone area due to the cut out, so I wanted to try a saddle that would spread the weight a bit more evenly. Always liked the look of the Antares and so far so good.
PostPosted: Sat Mar 15, 2014 10:11 am
I use both Kium and carbon braided. To me carbon braided seem to be stiffer and my Kium doesn't seem to have lasted as long before sag set in (don't know why that should be if the body of both is the same so it's probable saddle specific).
From what I'm reading here aboutthe carbon top of the 00 lasting longer I may well upgrade next time.
PostPosted: Sat Mar 15, 2014 2:32 pm
The 00 has noticeably less padding than the standard Kiüm railed version. I have ridden 3 flavors of Antares for the past 5 years so I would think I have some insight into this. You will feel the padding difference in 4+ hour rides.
PostPosted: Sat Mar 15, 2014 8:26 pm
definitely less sag over time with the 00 compared to Kium/braided nylon versions. I don't mind the sag too much though, still a reasonably stiff shell...
PostPosted: Sat Mar 15, 2014 10:07 pm
Anyone any experience with the new R1 or R3. The shell looks very similar to the 00 and has a similar foam core.
PostPosted: Sun Mar 16, 2014 12:15 am
If the lack of a center channel does end up bothering you, the VS version has a slight depressed center channel. I went from a Specialized Romin Evo with center channel and felt that the Antares VS was even more comfortable.
I have a kium version on my trainer bike and a carbon railed version on my carbon frame. Not sure I can tell a flex difference on one or the other. Same shell, different rails.
PostPosted: Sun Mar 16, 2014 12:24 am
The Fizik Versus (VS) channel is not that deep, but the Versus X (VXS) is deep.
PostPosted: Wed Jun 10, 2015 9:18 pm
I am looking at getting the Fizik Antares and trying to decide which model to go with. I think I have it narrowed down to the VS and the 00, maybe even the VSX even though I have read mixed reviews with it. Ultimately I like the 00 but I have only test rode the VS with Kium rails. It felt great but I'm wondering if the 00 would feel just as good and save on some weight and sagging over time. I'm still uncertain and haven't rode enough saddles to tell if the center channel stuff actually works or if it's just marketing.
PostPosted: Wed Jun 10, 2015 10:50 pm
Center channel stuff works, but the width of the nose makes a lot of difference depending on your anatomy. I'd love to see fizik make something similar to the ISM saddles, only lighter and better looking.
PostPosted: Thu Jun 11, 2015 9:46 pm
Does anyone have any experience with the VSX compared to the VS?
PostPosted: Thu Jun 11, 2015 10:02 pm
I've used the manganese version, the Kium and the braided version, can't really tell the difference between the 3 of them. I've haven't used the 00 version so I can't comment there but this is by far my favorite saddle and I weight 81 kg. Only complaint I could make I broke the shell once when I took a pothole at about 45km that was the Kium version but very comfortable saddle in my opinion
There are no new unread posts for this topic. Fizik Antares 00 - Bib Shredding
p3dalfaster
11
1108
Thu Jul 20, 2017 8:59 pm
Tomdaws View the latest post
There are no new unread posts for this topic. Selle italia k. Carbonio vs Fizik Arione/Antares
gitsome
11
1848
Mon Mar 06, 2017 9:23 am
madik View the latest post
There are no new unread posts for this topic. Fizik R3B shoes
liam7020
Mon Apr 17, 2017 12:58 pm
liam7020 View the latest post
There are no new unread posts for this topic. Fizik bars and stems 2018?
Titusrider
Mon Dec 04, 2017 11:02 pm
Titusrider View the latest post
There are no new unread posts for this topic. Attachment(s) fizik braided carbon rail on selle italia monolink seatpost
seansis
Thu Oct 19, 2017 1:24 pm
seansis View the latest post
Users browsing this forum: Allen254, billspreston, ChaosHokie, ewwhite, Ltoddokc, Martin.F, nobuseri, rasmusic, Yahoo [Bot] and 41 guests
