Zipp SL-70 Aero
dmoneysworks wrote:I just ordered my SL sprint stem and hoping that my SRM PC8 Computer mount fits as easily as a garmin one
Good luck with that... The SL Sprint + SL-70 combination will leave you with scarcely more than a cm of usable space on either side...
I've always liked the shape of these bars but not too keen on the finish. Would light sanding be my only option to lose the decals?
I saw an adapter for sale on eBay. It was like $50 though.
...you're right, it's touching the pc8 mount where stem face plate is at it's most bulbous.
I think I'm just going to shave a little corner away from the pc8 mount (dremel) and see how it goes...
40cm zipp sl70 aero h'bars with zipp sl sprint stem and pc8 mount
Photo shows pc8 mount with clamp bolt loose, ...so as it cinches up it hits stem face plate and pushs the pc8 mount outwards
- Moderator
Never understood why there isn't 10mm more round section on this type of bar. Is saving .5w on a CFD model really worth the impact on practicality?
Using Tapatalk
I had to mill the clamp band of my Sigma mount to about 60% of its original width for it to work on my Vuka Sprint.
Perhaps clamp width should be a more accessible spec just like stem stack.
BeeSeeBee wrote:Well, it is right on their page
on all/most stem manufacturers?
I haven't really looked. I can fit my K-Edged on mine with Zipp SL stem and there's no problem at all with room.
Ah, I thought you meant the usable clamp area of the bar. Zipp also has the clamp width of their stems, so but Extralite doesn't (not that it would really matter with the 50mm clamp area of the Sprint bar, things are going to be tight no matter what). I've got the same setup as you and have plenty of room to spare, they fortunately widened the clamping area on the SL-70 Aero 20mm, though a light is still a tight squeeze.
fh8425 wrote:after countless of trying ... i settled with this way of mounting the garmin and front light on my zipp SL-70 aero
Bar tape on the aero section kind of defeats the purpose. Then again, so does the light.
