It is currently Wed Feb 22, 2017 1:21 am
PostPosted: Tue Mar 11, 2014 1:38 pm
I'm planning to purchase a BMC SLR02 and fit my existing Centaur groupset (currently fitted to an '09 Scott CR1). The BMC comes with 105 fitted.
Does anyone have a comprehensive list of parts required to fit the crankset? The BB bearings have had a fair bit of use so really I'd like to refresh the lot.
Campagnolo; because I ride a bicycle, not a fishing rod.
M∆SON Definition / Camapgnolo endurance & bikepacking build - ~8.4kg
PostPosted: Tue Mar 11, 2014 2:04 pm
http://www.competitivecyclist.com/campa ... 86-adapter
should be it.
Official cafe stop tester
PostPosted: Tue Mar 11, 2014 2:08 pm
So does that replace the standard screw-in cups and use regular bearings?
PostPosted: Tue Mar 11, 2014 3:41 pm
from how i read it, the pf86 is like a bb30 shell but with nylon cups (ala pf30) and bearings to fit a standard 24mm axle (HT2).
These adaptors press in and enable the use of the campag pt bearings which are on your cranks , not in a cartridge type bottom bracket.
And Devon, might be nice and rewarding if you did some homework for yourself occasionally :thumbup:
PostPosted: Tue Mar 11, 2014 4:50 pm
That defeats the point in a forum :wink: Advice from someone with first hand experience beats Google any day.
What's confusing me is if this adapter is just a replacement for the cups or if it includes a bearing? Power Torque uses a cartridge bearing so do I need to replace that as well as purchasing this adapter?
PostPosted: Wed Mar 12, 2014 2:18 am
For a threaded bottom bracket Campagnolo sell the cups alone. Bearings come on the crankset.
Same for BB86. Buy these press in 'cups'. Bearings are on your crankset.
If you need new bearings you need to buy new bearings.
PS. I have an SLR02 (the red/black that comes with 105). I put a Red group on it. Excellent frameset. Almost on par with my Parlee Z5 for much less cost. The only thing you give up is 200grams.
Grover's Grumblings
Grover's Garage
PostPosted: Wed Mar 12, 2014 2:38 am
Are you going to buy a frame that fits this time, or are you planning to stick with the 'frog on a matchbox' look? viewtopic.php?f=10&t=119051
PostPosted: Wed Mar 12, 2014 9:30 am
if the frame has a BB86 BBshell then Jekyll's suggestion is probably the only option. Suggest you confirm this first, as all advise is dependent on this. BB86 is a pressfit system.
Several misunderstandings here about a PT crankset.
The DS bearing is pressed onto the crank spindle.
The NDS bearing sits in a cup. So with that kit, only the NDS bearing is provided.
Check the DS bearing after the crank is removed. It may well be fine.
There's sometimes a buggy.
One.
duplicate
One.
PostPosted: Wed Mar 12, 2014 9:46 am
That was my thinking. Always wanted an SLR but can't justify the 01!
This is where I was coming from. Thanks!
Are you going to tell Taylor Phinney (same height as me) that his 58cm GF01 is wrong too? I'll continue riding what's comfortable for my body shape, thanks. In the case of the SLR, the 60 has the same length TT as the Scott and is the biggest size they do.
There are no new unread posts for this topic. Carbon saddle not fitting
rbynck
Fri Aug 12, 2016 9:12 pm
TheKaiser View the latest post
There are no new unread posts for this topic. Attachment(s) Bike fitting on Colnago v1-r
pdiomidis
41
2458
Wed Dec 28, 2016 5:21 pm
Fiery View the latest post
There are no new unread posts for this topic. bike fitting and suggestions help
bigpab
Sun Jan 22, 2017 11:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Selle SMP saddles - advice on fitting and model selection?
rynogee
11
1016
Mon Dec 26, 2016 5:32 pm
ryanw View the latest post
There are no new unread posts for this topic. Attachment(s) anyone know the torque spec for this?
addictR1
14
928
Sat May 28, 2016 6:39 pm
BRM View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], MSNbot Media, Yahoo [Bot] and 31 guests
