AX Lightness Morpheus Crankset Assembly
simpatsco
by simpatsco
Looking for some advice on installation please. I am fitting the compact Morpheus to a Storck Fascenario G2, with an 86.5mm BB shell. Am using the Rotor 4130 Pressfits, held in good with Loctite. I have fitted the spindle (30mm) with the lip in contact with the drive side bearing, as per instruction from AX.
Question - Do I need a washer on the NDS to space up the NDS crank arm. Any (sensible) tightening of the NDS crank arm seems to compromise the bearing's ability to spin freely. If so, what kind of washer? Wavy?
AX's instructions refer to a "shaft washer" sitting against the NDS bearing. Anyone know what they mean?
many thanks
