It is currently Thu Apr 27, 2017 6:02 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Mar 10, 2014 9:21 am
I was out riding my summerbike for the first time yesterday, and I noticed that the chain or dereailleur was behaving a bit weird. It's a bit difficult to explain, but it felt and sounded like when a gear is skipping, although it wasn't. It came with every second pedal rev, and just gave a slight bump in the chain.
I can't seem to find a stiff link in the chain, and I'm pretty sure the derailleur is adjusted correctly.
I'm wondering if it's because the chain is too short. I recently went from 50/34 to 52/36 chainrings. Could that be the reason?
Any other things to look at? The chainringbolts should be tight enough as well as the crank itself.
If you dream of being famous - think of what birds do to statues.
Instagram: https://www.instagram.com/kermithimself/
Youtube: https://www.youtube.com/channel/UCdCPaXwpeXT_LpuEF0REjqw
Facebook: https://www.facebook.com/gotlegscycling/
PostPosted: Mon Mar 10, 2014 10:06 am
Worn cogs/chainrings? Compatibility issues, maybe?
PostPosted: Mon Mar 10, 2014 12:58 pm
Probably a damaged or worn quicklink. this happened to me and my quicklink was about to go pop! replaced it and it was all ok!
PostPosted: Mon Mar 10, 2014 1:10 pm
I actually just fitted a new KMC Missinglink for 11 speed(I ride SRAM Red 22).
PostPosted: Mon Mar 10, 2014 1:42 pm
Couple of things. First if it happens in big-big crosschaining it might be the chain is too short and the derailleur wants to shift down the cassette.
Second, you shouldn't change the missing-link mid chain life. The idea is the missing-link and chain will age and stretch together. If you install a new one on an old chain its pins having started stretching yet it will be shorter than every other link in the chain and can cause a clunk every revolution. http://sheldonbrown.com/chains.html
I would put on a new, corrrectly sized chain first, they cost what $30-40? if that doesn't work I would look at the following.
Third, have you checked the derailleur cable tension, is the cable housing "gummed up" if it hasn't been used in a while, is the derailleur hanger straight, was something leaning up against it over the winter?
Evo 5.13kg SL3 6.77 Slice RS 8.89 viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Mon Mar 10, 2014 3:51 pm
could be a dumb question but you never know....
Did you take the chain off and put it back around a guide in the rear mech? :noidea:
Seen it done often enough..
Official cafe stop tester
PostPosted: Mon Mar 10, 2014 7:39 pm
Fitted a new Shimano chain, and the skipping disappeared. Interesting to see if the new Shimano chain will shift alright with the worn Red cassette.
There are no new unread posts for this topic. Scott Addict feels plush
addictR1
Tue Apr 18, 2017 6:07 pm
addictR1 View the latest post
There are no new unread posts for this topic. Winter drivetrain cleaning
gitsome
23
1148
Thu Jan 19, 2017 8:14 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Drivetrain smoothness troubleshoot
nemeseri
Fri Aug 26, 2016 9:59 am
helldiver View the latest post
There are no new unread posts for this topic. Powertap C1 and Campagnolo 10 speed drivetrain
ChristianB
Sat Apr 30, 2016 9:02 pm
ChristianB View the latest post
There are no new unread posts for this topic. SRAM Rival 22 vs 105 cassette with Force 22 drivetrain?
stockae92
Sun Jan 15, 2017 8:09 pm
Stueys View the latest post
Users browsing this forum: AZR3, BRM, gmarsden, Lightweenie, mariovalentim, PinaF8, Ritxis and 43 guests
