Installing Recon Cassette
drainyoo
by drainyoo
I just installed a Recon aluminum cassette onto my Mavic wheel and it's very loose. I tightened the lockring down tight and I used the included washer. Do I need to tightened it down even more or is this how it should be? I've installed a cassette on a MTB and I don't recall it moving around.
1415chris
by 1415chris
You just need a thicker spacer and you will be fine.
drainyoo
by drainyoo
Thanks. Would my LBS have these or are they uncommon washers? Any specific thickness I should get?
bikerjulio
by bikerjulio
My understanding that with a 10-spd Shimano spec cassette on the Mavic freehub, 2 spacers are needed - one from Mavic and one from Shimano.
Your LBS should be able to help.
Don't ride it in the meantime.
There's sometimes a buggy.
One.
drainyoo
by drainyoo
Gotcha. The Recon came with a spacer, and I assume this is the same as the Shimano spacer. Is there a difference between the Mavic and Shimano spacers, or are they all the same?
bikerjulio
by bikerjulio
Can't help on exact thickness. But I think the Mavic one is in the order of 1 - 2mm thick
One.
eric
by eric
The Mavic one is thicker than the 1mm Shimano one.
drainyoo
by drainyoo
Ok, thanks for the info folks. Will have to see if my LBS has the spacer.
