It is currently Sun Oct 22, 2017 5:56 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sat Mar 08, 2014 4:36 am
So, does anyone cross their cables when setting up beaded housings such as Nokon, AICAN, Alligator, and Powercordz Swift?
Do you run them in front of the bar or behind the bar?
Do you do it to have them perform properly or it didn't matter with any of the setup?
What's your favorite combination when setting up beaded housings, and why?
PostPosted: Sat Mar 08, 2014 1:31 pm
no
internal routing on my bars
this is the only way i've used nokon
nokon + powercordz liner + powercordz - because the nokon liner isn't as good as the pc one
PostPosted: Sat Mar 08, 2014 3:13 pm
Here is the setup that I put together with Nokon cables and Nokon liners and have zero issues. The nice part about these setups is you can shorten or lengthen the cables to your liking very easy. This setup shifts flawless on 6700 shifters and derailleurs.
http://flic.kr/p/kPDEea
PostPosted: Sat Mar 08, 2014 3:57 pm
Thanks, I'm looking at going to beaded housing. Your pic is very helpful.
Do you have problems turning the handlebars all the way to the right, or do you avoid doing that? It looks like the rear brake cable would get hung up. I ask, because this is how I get the bike in the back seat of my car.
Click-free.....
shoemakerpom2010 wrote:
.....Image
Trek Madone 7.9 58cm 14.9lbs
PostPosted: Sat Mar 08, 2014 4:18 pm
I measured out the length exactly by adding and subtracting beads until I was happy with turning the bars to the angle to put the bike in my van. That's the best thing about the system your not stuck with one length. :thumbup:
PostPosted: Mon Mar 10, 2014 2:20 pm
For those who does not have a internal cable frame, do you guys run the liner straight through the exposed part or do you just end the liner at the cable stop? Would running them through the expose portion have any detriment on performance?
PostPosted: Tue Mar 11, 2014 3:26 pm
I have the liner running from shifter to the derailleur no brake anywhere and shifting is spot on. Same with the brakes. That way there are no points for grit to enter.
PostPosted: Tue Mar 11, 2014 3:54 pm
I'm running two bikes with Nokons, one with crossed cables under the DT, one without (came from the shop like this). Would definitely recommend crossing, the cables have a smoother bend.
My handlebars only have a cable groove, under the tape I'm running a piece of plain Shimano cable housing. Same inside the top tube on the one bike where it's internal. The transition spot might cause friction though, there might be room for some improvement.
Are you guys running Nokons under the tape?
PostPosted: Fri Apr 11, 2014 7:53 pm
When installing the liners, concerning the length, should the the length be that the liner stays within the beads or the liner should extend to outside the beads?
PostPosted: Sat Apr 12, 2014 3:39 am
The liners extend past the length of the beads. The beds are 'held' together by the cable liner themselves. I also like to cross shifter cables under the downtube.
good luck
my YouTube channel- keep the grams down and the watts up!
-2014 Cipollini Bond Campagnolo EPS -2011 Time RXR ULTeam SR11 -2010 Colnago EPS SR11 -2013 Colnago C59 SR-EPS -2011 Colnago Prestige Di2 -2013 Specialized Shiv TT SWorks SR11 -2015 BMC TM01 DI2
PostPosted: Wed Apr 16, 2014 4:57 pm
Currently setting up Swift from Powercordz. When the cables is at it's tightest for the rear shifting, am I suppose to see compression on the housing entering the derailleur, especially a huge amount of it where the housing isn't straight anymore?
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. Link cable housing and internal full length runs?
SpecializedColnago
Wed Apr 12, 2017 1:53 pm
reknop View the latest post
There are no new unread posts for this topic. Shimano Brake Cable in Campagnolo Ultra-Shift Housing?
Valbrona
Thu Jan 05, 2017 11:05 pm
Valbrona View the latest post
There are no new unread posts for this topic. Fasi Niro Glide alumium brake and derailleur cable housing
tommasini
Fri Jan 13, 2017 10:07 am
micky View the latest post
There are no new unread posts for this topic. Tarmac SL bottom bracket cable guide mechanical setup
ak47
Mon Mar 27, 2017 12:11 pm
cyclespeed View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], jwfinesse, tonytourist and 31 guests
