It is currently Mon Feb 20, 2017 10:51 am
PostPosted: Fri Mar 07, 2014 7:05 pm
When clamping parts together with different torque recommendation, which do you use? For example, clamping a stem to a bar. Stem has a torque recco of 4nm and the bars has 5nm. Which do you go with?
6.24kg CAAD10
PostPosted: Fri Mar 07, 2014 7:08 pm
i always use carbon paste...and in your case, i would go with the lower only when using the paste for assembly.
- AX Lightness Vial EVO D + DA9070 + Enve SES 2.2 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Fri Mar 07, 2014 7:55 pm
You should always use the lowest value, otherwise you may damage the "weakest link" of the assembly.
PostPosted: Fri Mar 07, 2014 7:58 pm
A torque specification for a handlebar is nonsensical; a bar has no threaded parts.
I wrote a little post a few years ago answering this question in detail:
viewtopic.php?f=3&t=66911&start=5
If you're in tl;dr mode: use carbon paste on the bar/clamp interface, thoroughly grease the stem bolts and tighten them to the stem spec of 4 N-m. Remember to snug the bolts against the clamp until they're finger tight and then apply those 4 N-m in sequence and slowly. In other words, turn each clamp bolt roughly one turn at a time, alternating in an X-shaped pattern.
Cheers,
Jason
PostPosted: Fri Mar 07, 2014 10:17 pm
Thanks folks. My example was made up, but in the manual for my Zipp SL bars it does indicate a max torque for it. I've also seen other carbon parts without threaded parts to have torque limits. That's what I was asking about. But it was answered. I will use the lower number. Thanks.
6.24kg CAAD10
PostPosted: Fri Mar 07, 2014 10:50 pm
<Jobst>
Specifying a torque value for a non-threaded part hints strongly at incompetent engineering. (Or, more charitably, a moment of extreme engineering sloppiness).
A torque value is meaningless without thread pitch. This is equivalent to specifying a maximum speed in meters. In both cases, the value is means nothing on its own and more information is required.
</Jobst>
I'm glad you found the information you needed. While using the lower torque value, I'd still check very carefully to ensure that all parts are secure. At best, a handlebar that slips while riding is irritating. At worst, it causes a crash.
Cheers,
Jason
PostPosted: Sat Mar 08, 2014 12:30 am
Thanks Jason. Got it. So using carbon paste essentially let's you apply less torque to the bolts and still get a secure grip?
6.24kg CAAD10
PostPosted: Sat Mar 08, 2014 1:07 am
Yes; carbon assembly paste inhibits slipping. I'd use it on bar/stem and seatpost/frame interfaces if slipping was a problem without it.
For what it's worth, carbon paste is essentially grease with very fine sand in it. Theoretically, you could easily make your own.
Cheers,
Jason
PostPosted: Sat Mar 08, 2014 1:17 am
Awesome. Thanks.
6.24kg CAAD10
PostPosted: Sat Mar 08, 2014 7:35 am
Do not confuse MAX torque with recommended torque...two very different specs. This topic has been covered comprehensively on this forum in several previous threads. EM3
______________
My 2013 Cervelo R5
There are no new unread posts for this topic. Need Tubular recommendation
mnmasotto
Sat Jul 02, 2016 6:27 pm
Zoro View the latest post
There are no new unread posts for this topic. Need saddle bag recommendation
addictR1
9
963
Thu Jun 23, 2016 7:19 pm
eaglejackson View the latest post
There are no new unread posts for this topic. Front light recommendation
BugsBunny7788
16
958
Sun Jan 15, 2017 11:07 pm
ALAN Carbon+ View the latest post
There are no new unread posts for this topic. Do you ride with light? Any recommendation?
[ Go to page: 1 2 3 4 ]
stockae92
45
3158
Wed Jan 18, 2017 6:38 pm
stockae92 View the latest post
There are no new unread posts for this topic. Clothing recommendation for touring in the Alps (South Tyrol) in May
nemeseri
19
651
Thu Feb 09, 2017 12:09 pm
wingguy View the latest post
Users browsing this forum: erikerbest, PinaF8, raven14 and 20 guests
