It is currently Mon Jan 16, 2017 1:55 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Fri Mar 07, 2014 1:56 pm
Bought Record EPS for my Parlee Z5, which of course is not set up for electronic shifting. I've run the cables and it looks ok (not perfect, but acceptable). The big issue is that I have no good place to put the battery. I was working on a mount for behind the saddle, but that's becoming too complicated. So I was thinking, can I just glue the non-traditional mount on to the frame? What kind of adhesive can I safely use on CF and will it have enough holding power not to release during a ride on rough roads? Ideally, the battery would be under the down tube.
PostPosted: Fri Mar 07, 2014 2:41 pm
Interesting idea.
Back when SRM used wires, I used to glue-on sensors with my wife's hot-glue gun. That was very solid. I would bet that it would work for a Canpagnolo EPS battery. Once you got a really good bond on the base of the battery, you would need to put a thick bead around the outside edge, too. I don't think it would look too good, but it would be pretty solid and could be later removed without damaging the frame or finish.
 Post subject:
PostPosted: Fri Mar 07, 2014 2:54 pm
PostPosted: Fri Mar 07, 2014 2:59 pm
Isn't there a mount for the bottle cages? like and extension?
PostPosted: Fri Mar 07, 2014 3:01 pm
http://www.bike24.com/1.php?content=8;n ... duct=29165 this one :-)
PostPosted: Fri Mar 07, 2014 3:51 pm
I have attempted this when I attached my v1 battery to my Selle Italia CX Zero Teknologika saddle. I used the small mount and glued the mount [epoxy] to the all carbon saddle. I sanded the mount, cleaned the underside of the saddle [sanded it up a bit too]. All so both items had a place for the epoxy to 'grip'. I also used a bit of carbon fiber to take up any gaps so there was a nice solid surface for maximum hold. Clamped together for a week for maximum curing.
It lasted a whole .4 miles. On one small bump [rail road tracks] the mount came unglued and I was riding my bike home from the main voyage [back up a 15% hill] with the power unit dangling in the back.
Very short ride for the main voyage. I elected to drill a small hole and epoxied the mount. The second way ended being better and has lasted for a year. The bike now has a v2 battery.
So to answer your question, I have had no luck gluing the aluminium mount carbon fiber without some old school hardware [ie screws].
PostPosted: Fri Mar 07, 2014 6:42 pm
The bottle cage mount is not an option… The EPS V1 battery is large enough that I can only fit one bottle cage and then only if I mount it on the secondary holes (in the cage that is), which means only a small bottle. That's just not going to cut it for the hot summer rides...
PostPosted: Fri Mar 07, 2014 8:16 pm
Would something like sugru work?
I'm about to start experimenting with it, and from what I can see, it seems to be pretty robust.
Www.sugru.com
PostPosted: Fri Mar 07, 2014 9:57 pm
Strap the power unit holder using 3M automotive double sided tape and thin zip ties
PostPosted: Fri Mar 07, 2014 11:41 pm
Like the idea of the double sided tape.
PostPosted: Sat Mar 08, 2014 2:13 am
3M VHB tape is probably the strongest out there. Not sure if it's strong enough to hold a V1 bat pack but am using it to hold Garmin speed/cadence sensor.
PostPosted: Sat Mar 08, 2014 9:27 am
I'm using vhb to hold a speed controller into an RC buggy. Drops of 6 foot to flat at 30+mph aren't unusual.
Neither is crashing at significantly more than 30mph.
If you can get two decent matching surfaces, and prep them well, it's not likely to come loose. But if heat helps it go off too. (Ideally needs 24 hours to cure.)
PostPosted: Sat Mar 08, 2014 5:01 pm
Made a bracket this morning… Basically, just a piece of steel bent to fit the profile of the bottom bracket and fastened to the battery with a screw and to the frame with the screw holding the cable guide. Actually much sturdier than I though it would be! Now I just need to figure out how to tuck away the excess cables.
PostPosted: Sat Mar 08, 2014 8:33 pm
which automotive tape? We use at least half a dozen different grades, depending on application. The strongest is the VHB mentioned below.
PostPosted: Sun Mar 09, 2014 11:53 am
there is not one single product called Vhb. If you look in the 3m catolog you'll see they offer severall versions, all with different characteristics. I normally use the sort that also work under lower tempatures and use a adhesive enhancer on both surfaces since just vhb on not perfectly smooth carbon won't hold too long. With a few piece of this stuff I stuck a large spoiler on the boot of a car and after several years and speeds over 150 mph it stil is on.
Downside is that vhb is made for professional use and only available in lagers quantities.
There are no new unread posts for this topic. di2 battery holder for Pina F8
fh8425
Tue Jul 12, 2016 12:18 am
fh8425 View the latest post
There are no new unread posts for this topic. Di2 battery voltage after charging
Zzyzxx71
Thu Aug 04, 2016 2:42 pm
Zzyzxx71 View the latest post
There are no new unread posts for this topic. stages battery life?
Delorre
7
577
Fri Oct 07, 2016 3:47 am
dmulligan View the latest post
There are no new unread posts for this topic. DI2 firmware Query after changing battery
frankp2112
Sat Sep 03, 2016 8:02 pm
goodboyr View the latest post
There are no new unread posts for this topic. diy 6870/9070 Di2 internal battery
weastman
10
1705
Wed Oct 19, 2016 6:56 am
VengeSWrks View the latest post
Users browsing this forum: Baidu [Spider], em3, Google Adsense [Bot], sarion, SuperDomestique, Yahoo [Bot] and 43 guests
