It is currently Sun Dec 17, 2017 3:24 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Mar 06, 2014 7:54 pm
Hi
Is tune kong freehub body valud for tume mag 170 hub?
Thanks
PostPosted: Thu Mar 06, 2014 9:26 pm
Not sure I'm totally clear on your question, but I believe you want to know if you can use the freehub body from a Kong on a Mag170... There are a few answers.
First is the year. The kong in recent years has had both blue (17mm) and red (15mm) freehub bodies. The same is true of the Mag. The 170 uses the blue and the 180 uses the red. If both of your hubs are the older red colored version, yes they are exactly the same.
If both of your hubs use the newer blue freehub body then yes you can use a Kong body on a 170, but it will not accept an 11 speed shimano/sram cassette. The Kong body is 10 speed shimano/sram only.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Thu Mar 06, 2014 10:25 pm
Ok
My freehub is blue for campagnolo and I want to change for shimano 10 speed
I have seen one used kong blue for sale so I ask this
Sorry I don't speak very well
PostPosted: Thu Mar 06, 2014 11:29 pm
The freehub body will swap fine, but since you've got a campag and are putting on a Shimano 10 you'll need a new end cap and the end cap from the kong will not be the proper one.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Thu Mar 06, 2014 11:56 pm
I have durace and ultegra cassette and I want mount a shimano cassette in kong body
What is the problem?
PostPosted: Fri Mar 07, 2014 12:10 am
The problem is that your 170 hub currently has an axle end cap that works with a Campagnolo freehub body. When you change to the Shimano freehub body you'll need a different axle end cap made for the Shimano freehub body (campag and shimano end caps are not the same). The axle end cap from the Kong hub will not be the right one because it is designed for a frame with 135mm spacing and the 170 is made for 130mm spacing.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Fri Mar 07, 2014 12:15 pm
And how is this end cap?
Do you have any pic?
Is possible to buy?
There are no new unread posts for this topic. Tune freehub
steelme
7
810
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
There are no new unread posts for this topic. Speedplay Tune ???
1spd
16
2018
Thu Apr 06, 2017 1:19 pm
kode54 View the latest post
There are no new unread posts for this topic. Re-covering tune speedneedle
Martin.F
Thu Mar 02, 2017 2:03 am
Fixie82 View the latest post
There are no new unread posts for this topic. Tune Gum Gum in an S-Works Tarmac fork
morganb
Thu Nov 09, 2017 6:10 pm
4ibanez View the latest post
There are no new unread posts for this topic. Setting up AX3000s with Tune housing
4ibanez
Fri May 12, 2017 5:23 am
shimmeD View the latest post
Users browsing this forum: ChristianB, kookie and 37 guests
