It is currently Sun Jan 21, 2018 5:54 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Mar 06, 2014 5:19 pm
Long story short I have Cervelo S5 frame with stock rotor bottom bracket pressed in, and FSA Gossamer BB386 EVO crank. I don't have any additional spacers and wave washers. After "proper" installation there is a side play of about 6-8 mm caused by too long crank spindle. First question is if it's possible to use FSA crank with rotor BB. If an answer to 1st question is "yes" than, what should I do to get rid of a gap between BB bearings and crank arm.
PostPosted: Fri Mar 07, 2014 6:12 pm
anwser 1st question : no, you should find an adapter!
BB386 : 86.5mm
BBright : 79mm
PostPosted: Sun Mar 09, 2014 1:13 am
What do you mean by "adapter"? New FSA bottom bracket or some spacer for rotor?
PostPosted: Sun Mar 09, 2014 7:01 pm
a 9.5 mm spacer between right crankarm and rh side bearing should do it
these are in fsa's 'catalogue'
PostPosted: Wed Jul 23, 2014 11:13 pm
I hate to bring up a dead topic but I am looking to get a 386 evo crank for a bbright cervelo. I have no idea where to find this spacer, yes I checked the 2014 fsa catalog. Does anyone have a link where I can buy it?
Strava
Bicycle1
Bicycle2
PostPosted: Thu Jul 24, 2014 12:38 am
Rotor 3d+ is essentially a bb386 crank. Whatever is required to install it on a Cervelo, should fit your crank. Disclaimer: I do not have a BBRight frame, so I do not have actual experience
PostPosted: Thu Jul 24, 2014 1:40 am
for some reason i thought the spacer with the rotor was 11.5mm but i don't remember for sure.
Strava
Bicycle1
Bicycle2
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram in BB386
wheelzqc
Thu Aug 03, 2017 4:30 am
wheelzqc View the latest post
There are no new unread posts for this topic. Sram Red BB386 crank arm compatibility
Jian81
Sun Dec 17, 2017 2:00 am
Jian81 View the latest post
There are no new unread posts for this topic. Between frame sizes - : Going larger frame vs going smaller frame
jeffy
16
1789
Sun Jul 09, 2017 11:03 pm
sooni View the latest post
There are no new unread posts for this topic. Hi-Mod frame vs non-himod ? Different frame quality ?
[ Go to page: 1 2 3 4 ]
destinationwarmth
49
7937
Sun Apr 16, 2017 7:58 pm
Hexsense View the latest post
Users browsing this forum: Bing [Bot], Delorre, DeRibble, em3, JayUK, LionelB, micky, wobbly and 32 guests
cron
