New Microshift
Here's the first article I've seen about it.
http://www.bikerumor.com/2014/03/07/tai ... rivetrain/
Sent from my Nexus 7 using Tapatalk
vdrey wrote:Here's the first article I've seen about it.
Thanks for sharing that, vdrey!
Meh...
Props to microSHIFT for proving that the approach of "reverse-engineering" name brand forerunner's stuff is a smart way of arriving at an alternative, more affordable solution. Why reinvent the wheel, after all?
The main thing that swayed me to choose - instead of the "Big 3" - the two microSHIFT groups that I currently use on two recent custom builds, is the colorful aesthetics microSHIFT offers in their "White" and "Arsis" lines. Their colors match beautifully with the color schemes that appeal to my tastes. Their third-tier "Centos" line (and all the lower-tier lines) has always left me underwhelmed.
I think I now understand the real reason for the "muted response" at Taipei that maxxevv reported in his post above. The visual aesthetic of microSHIFT's Centos 11 speed is yawn-inducing; in my opinion.
Since all the marketing hype out there has failed to convince me that I need 11 speed, I'll stick with either their 10 speed "Arsis" or "White" lines for my next custom build.
The muted response from the media is because they know that any article they write will not get much interest from the public, so they head off to find something they think will generate traffic.
The only innovation offered here is the thumb shifter. But I still say good on microshift for fighting on. They need to find some way to get some OEM sales. Maybe they shold chase the non conventional areas the other OEMs over look. I'm thinking recumbents and trikes etc.
velonista wrote:vdrey wrote:Their colors match beautifully with the color schemes that appeal to my tastes. Their third-tier "Centos" line (and all the lower-tier lines) has always left me underwhelmed.
I have been considering Microshift for my budget build for some time. Real budget build.
totoboa wrote:velonista wrote:Their colors match beautifully with the color schemes that appeal to my tastes. Their third-tier "Centos" line (and all the lower-tier lines) has always left me underwhelmed.
I have been considering Microshift for my budget build for some time. Real budget build.Have you actually installed and used the Centos or have you simply gone with the higher tier Arsis for the aesthetics alone ? I am unable to find if the mini groupers are really any different in FUCTIONALITY. Material, color, etc vary but does the operation of the system, does the useability change ? - thanks
I can't vouch for their Centos line. I only have actual experience with microSHIFT's White mini-group. It's so nice, I bought it twice for two different bikes
You are probably right about the functionality being the same across the different lines. The most obvious differences between the different lines are the materials, weights, and color options. Maybe the ergonomics on the shifters are better the higher you go up the lines. But I'm only speculating 'cause I can only go by White. Also I suspect the more recent iterations of a particular line would have tweaks that that line's previous year's release won't have.
I don't have any hands-on experience with the Centos line. But this guy does:
martincashman on bikeradar.com forum wrote:Re: microshift vs normal shimano shifters
I upgraded my winter bike from Shimana Sora 8speed to a Microshift Centos 10speed and they work great, my other bikes have Shimano 105 10speed. Whichever shifters you use, they just take getting used to, with Microshift, initially I kept trying to flick the brake lever to change but once I got used to the two levers, they work fine with thick winter gloves. Going back to Shimano 105 now seems awkward and will have to be relearned in Summer.
On performance, Microshift and 105 are almost identical, Microshift rear derailleur is better, bought a 2nd one as a replacement for 105 on one bike. The Microshift front chainring shifter is a bit slower than 105 tho, it must be said that I didn't change over from 8speed chainrings so maybe this is a factor. Front shifting isn't as critical, so this is not a big issue.
Very surprised more bike makers don't fit Microshift on bikes instead of Shimano and spend savings on better wheels.
You can find that post and others on this microSHIFT review compilation.
maxxevv wrote:....Strangely muted response/coverage at the show though....
It's not that strange when you consider the function of their last groups...
- Similar Topics
- Replies
- Views
- Last post
- 24 Replies
- 1202 Views
Last post by SixThirteen
Sun Mar 04, 2018 11:44 am
