It is currently Tue Jan 23, 2018 12:58 am
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: BTP Hoods Installation
PostPosted: Fri Feb 28, 2014 9:54 pm
I have a new pair of BTP hoods and am having a problem getting them installed over the SR levers.....actually the thumb lever. I remember having this problem about 4 or 5 years ago, but can't remeber how I solved it. I don't want to tear them. I tried a little soap inside and that didn't work. Thinking about trying to heat them up with a hairdryer. Any suggestions would be appreciated?
PostPosted: Fri Feb 28, 2014 10:07 pm
I remember reading on here that soapy water helps with installing.
BTW, where did you find them? I've been looking to purchase a set and can't find them anywhere.
6.24kg CAAD10
PostPosted: Sat Mar 01, 2014 12:09 am
Unfotunately, I got the last set that one of the WW members had. I tried the soapy water this time and although they slip over the top, I can't stretch the rubber over the thumb lever...even with prying.
PostPosted: Tue Mar 04, 2014 12:03 am
Problem Solved. I heated up the hoods in the oven at a low temperature and that made the hoods more flexible, but still could not get them on....and then I discovered that the slits on the side and bottom of the Campy hoods was longer than on the BTP hoods. I used a small hole punch at each end (very clean holes) and voila!
PostPosted: Tue Mar 04, 2014 12:30 am
Glad it's solved!
I'm so jealous you got a set of those. :cry: :thumbup:
PostPosted: Tue Mar 04, 2014 3:30 pm
Thanks for the info. Now I just need to find me a set.
6.24kg CAAD10
PostPosted: Tue Mar 11, 2014 10:18 am
Or you can make your own:
viewtopic.php?f=3&t=102208
My experience with the original BTP-hoods is that they are not exactly the most impressive handywork...
~ Men of steel need fibre ~
There are no new unread posts for this topic. Tape instead of hoods?
whydobearsxplod
13
1464
Fri Sep 29, 2017 4:46 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. Show me ur handlebar/hoods...
3Pio
Sun Aug 13, 2017 9:59 pm
3Pio View the latest post
There are no new unread posts for this topic. Campy Brake Hoods
16Los
Fri Apr 14, 2017 5:59 pm
DJT21 View the latest post
There are no new unread posts for this topic. Chasing that elusive perfect transition to the hoods
jever98
Wed Aug 30, 2017 4:52 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. Shimano 8020 hydraulic shifter hoods
Flint
Mon Dec 11, 2017 1:57 pm
peted76 View the latest post
Users browsing this forum: audiojan, Baidu [Spider], Bing [Bot], glam2deaf, Google Adsense [Bot], JS300, Majestic-12 [Bot], nestornnk, pdlpsher1 and 35 guests
