It is currently Fri Jan 19, 2018 9:13 am
PostPosted: Fri Feb 28, 2014 4:16 am
I'm stuck with using a specialized 1 bolt saddle clamp like this, which is used on most Specialized seatposts:
The thing weighs 61grams, which is quite a lot. Does anybody make an aluminum version of the shell or a Ti center bolt (it appears to be a fairly custom bolt).
PostPosted: Fri Feb 28, 2014 10:24 am
Well, as I was afraid, I finished building up the new Venge and it came out a hair over 15lbs....15.16. The seatpost and bars put me over the edge. Everything else is pretty light.
PostPosted: Fri Feb 28, 2014 4:13 pm
Dura Ace 7900 light? lol, sorry had to do this :lol:
Back on topic, I think it should not be that difficult to produce the two inner parts of the clamp in carbon.
Just make a countermold based on the original parts an fill it with fibres and epoxy.
You may want to keep the outer as they are just for safety.
PostPosted: Fri Feb 28, 2014 4:22 pm
Very nice looking bike and for an aero bike its plenty light enough. I'd much rather have your bike at its current weight than one built with cheap Sram parts at a few less grams.
PostPosted: Fri Feb 28, 2014 5:30 pm
Wow, that's heavy. My guess is that someone might have a Ti version of that bolt, or something similar. I'd check with Toronto Cycles or ProBolt.
BTW, beautiful bike.
6.24kg CAAD10
PostPosted: Fri Feb 28, 2014 10:29 pm
That is a heavy part, would also like a lighter version for my Venge, or at least a black bolt.
Nice weight btw!
2015 S-works Tarmac DA9000, 6,29kg
PostPosted: Sat Mar 01, 2014 5:29 am
The clamps are aluminium so you can only shave weight from replacing the bolt. I got someone to make some ti ones for me a while back
PostPosted: Sun Mar 02, 2014 2:07 am
In for a solution to reduce the weight on my CG-R post also. Went from a 125gr Woodman to a 200+ gr CG-R.
There are no new unread posts for this topic. Attachment(s) alu bolts in saddle rail clamp
wwnick
Sat Jul 29, 2017 9:23 pm
donald View the latest post
There are no new unread posts for this topic. Has anyone successfully modified a saddle clamp to take oversized rails?
alcatraz
Mon Dec 11, 2017 12:21 am
apctjb View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized Seat post clamp woes
StickyBottle
Thu Aug 24, 2017 2:39 pm
StickyBottle View the latest post
There are no new unread posts for this topic. Specialized Power Expert Saddle - Weight
velobob
Mon Jun 05, 2017 4:16 am
chazmtb View the latest post
There are no new unread posts for this topic. 30.8mm seatpost clamp on 30.0mm frame
Luca79
Fri Jul 28, 2017 7:01 am
kman View the latest post
Users browsing this forum: Google Adsense [Bot], Rippin and 38 guests
