It is currently Fri Dec 15, 2017 12:20 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
 Post subject: Freezing BB30 axle
PostPosted: Sat Feb 22, 2014 3:32 pm
Does sticking the BB30 axle in the freezer (or outside in Winnipeg where its -30) really make it easier to install?? I'm installing a new 109mm in my EVO I got it in part way and now it just won't go any further.. I am reluctant to take the hammer to it because its an SRM Hollowgram SISL2 setup... something just doesn't seem right about whacking an SRM...
The new KP248 109mm setup seems so hard to install without a fight (re hammering the axle) the old Cannondale spindle would install/uninstall with 2-3 hits...
 Post subject: Re: Freezing BB30 axle
PostPosted: Sat Feb 22, 2014 4:21 pm
definitely helps putting it in the freezer, also heat up the bottom bracket with a hairdryer, should just slide in nice and easy.
good trick for installing bearings too.
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
PostPosted: Sat Feb 22, 2014 6:30 pm
Now that's its part way in instead of hitting it with the rubber mallet just yet. Grab some compressed air from the store (2 or 3 cans) and turn the can upside down and spay the air on the axel where its going into the bearing on all sides. Since the axel is hollow spray the inside also a lot. It should shrink immediately and you can continue. It works the same when removing the axel. Be genital when tapping the new 109 axel because you can damage the threads and not be able to get the pedals in. :thumbup: Done this many times and it works every time. :mrgreen:
PostPosted: Sat Feb 22, 2014 10:05 pm
Be genital?
My RCA
PostPosted: Sat Feb 22, 2014 10:26 pm
^ :lol: :lol:
PostPosted: Sat Feb 22, 2014 10:45 pm
Come on, it's just a typo. No need to be a dick about it.
PostPosted: Sat Feb 22, 2014 11:18 pm
PostPosted: Sat Feb 22, 2014 11:19 pm
Thats why cold shrinks it.
My RCA
PostPosted: Sun Feb 23, 2014 1:09 am
Lol :noidea: Someday I will learn to type.
PostPosted: Sun Feb 23, 2014 4:44 am
haha well thanks for the replies.... LOL
And on a sidenote.. the freezer trick did NOTHING for me.... Ive had this problem from day one with this new 109mm BB in my EVO.. I stuck the axle in the backyard today for 2 hours where it was -30 with the windchill... it still did not want to push through... I against my will leaned into with the rubber mallet and it wouldn't move... it gets to the point where theres about 1/4 inch to go and it just says NO WAY... not moving.. I even tried using the compressed air trick as well...
What I ended up doing after things warmed up was pull the cranks right off... taking a regular hammer (I know.. but the rubber mallet does not work) I tapped it 3 times, went in a little bit.. put the SRM back on and tq'd it.. this pulled the axle back to the DS crank arm.. I then put the NDS crank on a tqd it and all is well...
I don't know why this is such an issue with this frame.. its almost like something is out of alignment....
My old SuperSix... put the axle in 2 whaps and in she went with the old 103mm axle!!
PostPosted: Sun Feb 23, 2014 9:05 pm
I so did not like having to use a rubber mallet to get the SISL2 spindle installed for my Hollowgram SRM. My solution was to use fine grade Emory cloth to wet 'polish' the spindle diameter while spinning it with a cordless drill. 30-40 seconds and the spindle can be hand fitted with no need for the hammer.
PostPosted: Sun Feb 23, 2014 10:20 pm
So its not just me.... good to know....
Ive never had so much grief in my life... its really turned me off the whole BB30 thing... Ive never liked it anyways being a Campy guy I love the Ultra Tq setup.... but running a Cannondale SRM has limited me to the 109 spindle option... especially since I have a pre PF30 beveled edge design one..
PostPosted: Tue Feb 25, 2014 1:23 pm
Honestly mate, get some fine sandpaper and sand that crank down till it fits by hand. I have done it, it is easy, and a perfect solution. You should not need a mallet to install, if the spindle, bearing interface is that tight, just imagine what is happening to the bearings.
PostPosted: Wed Mar 12, 2014 1:30 am
Soooo I am wondering if Cannondale has changed the specs slightly on the 109mm spindle... I just installed a new one in my Cannondale Slice RS, and it slid through by hand with 3 taps of the rubber mallet to seat it... I did nothing differently at all.... I am starting to wonder if my BB shell is not in perfect alignment on the EVO... I am not going to pop the Evo out and try the other one.. way to much headache....
PostPosted: Wed Mar 12, 2014 7:27 pm
Just wondering: were you able to get the 109mm spindle on its own or whether you had to buy the entire ceramic BB kit.
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Mag 150 with Carbon Axle?
whydobearsxplod
Fri Sep 29, 2017 11:30 am
ms6073 View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
315
Wed Dec 13, 2017 12:42 pm
There are no new unread posts for this topic. BSA 68 support for 30[mm] crank axle
Shmitt
10
863
Sun May 07, 2017 1:13 pm
bikerjulio View the latest post
There are no new unread posts for this topic. 30mm Axle / BB Spacer with < 0.5mm height?
jbattermann
Tue Aug 08, 2017 6:36 am
sungod View the latest post
Users browsing this forum: grymg, Quattroporte, TobinHatesYou and 16 guests
